Egt help
Old Apr 14, 2012 | 06:26 PM
94iditrbo's Avatar
94iditrbo
Egt help
I did a search and didn't find the answer to my problem. I have a 94 turbo with auto. I have turned up the pump 1.5 flats put on a dp and 3" exhaust adjusted the pump about a dime with toward the passenger side. I hooked up to my 6000 lb travel trailer today and took it for a test after changing my trans fluid and filter. When cruising in OD at 55 my EGT would climb to 1150 with about 1/4 throttle and about 5 lbs of boost. I turned off OD and boost would go up to 9lbs and the egt would back off to 950 with the rpms about 2500. I am wondering if my timing is off or do I need to turn up the fuel more? It doesn't blow any smoke when loaded up or when I get on it at full throttle. Also what is the normal operating temp for an Auto? I was seeing 250 the other night running unloaded at 70.
Old Apr 14, 2012 | 06:47 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
is that trans temp? were do you have the temp sensor?
Old Apr 14, 2012 | 06:50 PM
IDIDieselJohn's Avatar
IDIDieselJohn
It's normal for EGT's to go down in higher RPM's. Keep it out of OD when towing to keep your EGT's in a safe range.
Where is your temp probe for the tranny? Is it in the outlet cooler line? (the front most one, from the torque converter, to the first cooler?) if so, 250* there sounds about normal.
If your probe is in the test port, that's way to hot! You should be keeping it around 150-180* there.
Old Apr 14, 2012 | 06:52 PM
94iditrbo's Avatar
94iditrbo
Yes that is trans temp I put the sensor in the port on the side of the tranny where I have seen most people install it.
Old Apr 14, 2012 | 06:54 PM
IDIDieselJohn
Your running way to hot then!!! Does the truck even have an aux. tranny cooler on it?
Old Apr 14, 2012 | 06:56 PM
94iditrbo's Avatar
94iditrbo
Yes i put a large cooler to replace the factory one in front of the radiator it is about 11" square.
Old Apr 14, 2012 | 06:58 PM
IDIDieselJohn
Did you by-pass the factory lower Rad tank cooler? Or it is in series with it?
Old Apr 14, 2012 | 07:01 PM
94iditrbo's Avatar
94iditrbo
In series I figured that wold be the best way to install it.
Old Apr 14, 2012 | 07:03 PM
IDIDieselJohn
That is the correct way to put it.
First line out of tranny, into rad tank cooler, then out that, into Aux. cooler, than back to tranny.
But 250* running empty isn't good, nor normal at all!
Maybe your gauge reads high?
Old Apr 14, 2012 | 07:09 PM
94iditrbo's Avatar
94iditrbo
I think I have it going to aux cooler first then into the rad the gauge is brand new stewart Warner don't think it would read high I am hearing a strange noise from the bell housing area at times I think my toque converter is about shot.
Old Apr 14, 2012 | 07:10 PM
'94IDITurbo7.3
i would try a different gauge if possible.
Old Apr 14, 2012 | 07:11 PM
IDIDieselJohn
X2, and if the same readings are seen, then you might have circulation problems....
Old Apr 14, 2012 | 07:15 PM
94iditrbo's Avatar
94iditrbo
When I put the cooler on one of the line on the original cooler was kinked I don't know how long it was like that with the PO but it could have caused all my problems to begin with.
Old Apr 14, 2012 | 07:19 PM
IDIDieselJohn
It probably had restricted flow, and it overworked the pump.
Old Apr 14, 2012 | 07:58 PM
94iditrbo's Avatar
94iditrbo
I have the waste gate set to stay closed will it make a difference in egts if I set the rod back to normal?
