spark plugs
Old Apr 14, 2012 | 05:34 PM
rang5.0's Avatar
rang5.0
spark plugs
Has anyone on here stripped threads using an impact to remove the plugs?
Randy
Old Apr 14, 2012 | 05:49 PM
Beechkid's Avatar
Beechkid
I am not a proponent of that and in the 70's/80's saw many cross thread.
When I decided it was time to change the plugs (2006 Mark LT 4x2, 5.4, 35,000 miles) with the Motorcraft SP 515’s. Although I knew about the carbon build-up/plug removal issue, I decided not to change the plugs until there was a replacement plug that I was comfortable with…meaning I knew it was a good quality plug in terms of component design and construction. Although I did following the most recent TSB, I also relied on my experience back in the 1970’s when aluminum heads & intake manifolds were just entering the street scene and never-seize did not exist. Here are the exceptions to the TSB that I did…
1. I ran Lucas fuel injection cleaner, mixed at 3 times their recommendation in 1 full tank of gasoline. Purpose…if I was lucky, it would dissolve or loosen any carbon buildup (although many do a real fuel injection cleaning also- and it is probably a best practice to do if you have more than 45-50,000 miles on the plugs)
2. Although I am a fan of PB Blaster, I used a product called ChemSearch “Yield”. The issue I have with using carb cleaner is the lack of lubrication…..in the old days of removing steel plugs from aluminum heads, we use to mix up acetone & ATF…or of we needed more lubrication, kerosene & ATF, “Yield” provides this lubrication- much better IMHO than even PB Blaster.
3. Yes, I put anti-seize on the plug threads (I know the TSB says not to)
4. Of course…a lot of patience, I really doubt if I ever put more than 20-25 lbs of force during removal (purposefully)
The end result, only one plug even “squeaked” coming out (but it basically unscrewed like a regular plug- literally). Plug #4 was initially a little stubborn, but after the second try, then waiting about 30 minutes, it came out with very little effort…just kept wiggling the plugs (tightening/loosening) by 1/8th or even less of a turn- and they all came out without a single one breaking or any issue really. Another technique that can definitely be used is to loosen the plugs about 1/8 to ¼ of a turn, start the engine for about 1 minute- this allows the flame to travel up around the plug to burn off the carbon, let cool, then remove with the process I previously described.
As far as using an air ratchet, I can understand the theory of “shocking” the carbon loose, but I have also seen and experienced in my younger days some real disasters.
Actual working time: 2 hours…..including washing my hands, total time was 5 hours.
Old Apr 14, 2012 | 09:58 PM
Coskid's Avatar
Coskid
Randy
I have not heard of anyone stripping the plug by using an impact wrench to pull them out. Most use PB blaster twice at least before trying to remove them.
Old Apr 14, 2012 | 10:01 PM
Coskid's Avatar
Coskid
You certainly don't need to use an impact wrench to get the plugs out like beechkid has described. The big thing is to prep the plugs and take your time. Thanks for sharing your experience.
Old Apr 15, 2012 | 08:59 PM
70f100longbed's Avatar
70f100longbed
As a flat rate tech I cannot afford to take 5 hours to do a job that only pays 2.5hrs. There is nothing wrong with beechkids method and if you dont feel comfortable using power tools on spark plugs then it is the best method. I personally have done dozens of sets of 3v spark plugs using an air ratchet and have never damaged any threads. I might get one broken plug every other set I do. The key to getting them out intact is to get the engine hot and use a strong ratchet with enough torque to keep them turning.
DWinTX
2004 - 2008 F150
20
Jun 2, 2020 08:07 AM
Bobbys Big Red Rig
2004 - 2008 F150
19
Sep 5, 2017 08:09 PM
50th ann
2009 - 2014 F150
Apr 24, 2015 01:17 PM
Mcrafty1
Modular V8 (4.6L, 5.4L)
Oct 25, 2014 01:20 PM
SaneSyco
13
Jun 19, 2014 01:01 PM
