Mating C4 To 2.9
Old Apr 30, 2003 | 07:55 PM
K-COV's Avatar
K-COV
Question Mating C4 To 2.9
DOES ANYONE HAVE ANY INFO ON HOW TO GET THE APPROPRIATE TORQUE CONVERTER,FLEX PLATE, AND SPACER TO MATE THE C4 TO THE 2.9. I ALSO NEED A WIRING DIAGRAM FOR THE FUEL INJECTION SYSTEM AS I GETTING THE ENGINE OUT OF AN 89 BRONCO WITH MAN TRANS.
Old May 2, 2003 | 09:39 PM
canzus's Avatar
canzus
Mating C4 To 2.9
Easiest way to get a C4 for the 2.9 would be to
find a 2.8 from a mid to late 70's Mustang, as they did
use the C4, and I'm not certian, but the TC and flex plate
should bolt up, and have the right balance for the 2.9...
Old May 3, 2003 | 03:33 AM
pat67shorty's Avatar
pat67shorty
Mating C4 To 2.9
Or use a C5 that was used behind 83-85 2.8's. Same as a C4, but with a lockup torque converter.
Old May 4, 2003 | 09:39 PM
K-COV's Avatar
K-COV
Mating C4 To 2.9
THIS PROJECT, 2.9 WITH C4 IS A CUSTOM CONVERSION I AM DOING. I HAVE A GUY WHO I AM GETTING THE KIT FROM, WHICH WAS ORIGINALLY FOR A 2.8, TELLING ME THE 2.8 BELLHOUSING WILL BOLT TO THE 2.9 BUT THE SALVAGE YARD MAN TELLS ME IT WILL NOT BOLT UP."HES BEEN IN THE BUSINESS 30 YEARS" . WILL THE 2.9 BOLT UP?
Old May 14, 2003 | 10:52 AM
Rand's Avatar
Rand
Mating C4 To 2.9
please dont use all caps.
Old May 14, 2003 | 03:40 PM
K-COV's Avatar
K-COV
Mating C4 To 2.9
Old Jun 4, 2003 | 02:27 AM
pat67shorty
Mating C4 To 2.9
Yes it does bolt up. Use the 2.8 flex plate, flex plate spacer, and starter. "Junkyard Guy" is full of B.S. The C4/5 has succesfully been used behind many 2.9's and 4.0's. don't forget to hook up the kickdown, also.
Old Jun 13, 2003 | 03:11 PM
Majisto's Avatar
Majisto
Mating C4 To 2.9
I always thought the C5 was different than the C4? The C5 went onto be the A4LD and 5R55E which I have in my SOHC 4.0. Hmm...
Old Jul 4, 2003 | 06:28 PM
frankenbroncoII's Avatar
frankenbroncoII
Mating C4 To 2.9
i dont know about your tranny question but as far as you bolt pattern question, the 2.8 and 2.9 are the same block with same bolt patters, the only diff is the heads, and intake
Old Jul 8, 2003 | 01:59 AM
pat67shorty
Mating C4 To 2.9
Nope. the C3 trans used in 2.0/2.3/2.8 2wd/auto aplications became that POS A4LD. The C4/C5 are the same tranny, with a different valve body. If you are a 2wd, you can just used a C4. If you are a 4x4, then using a C5 out of a 4x4 ranger/B2 would be a bolt in.
Dean06919
Nov 27, 2016 10:27 AM
Glaser67
Engine Swaps
Jul 7, 2016 08:59 AM
crm318
Engine Swaps
21
Jun 26, 2015 09:31 AM
40dog
Jul 8, 2012 09:14 AM
28, 29, c4, ford, v6
