truck randomly wont start
Old Apr 12, 2012 | 09:46 AM
oryc124's Avatar
oryc124
I've recently had a random problem where my truck decides it wont try to start. All the light/gauges come on but when I turn the key after the WTS light turns off nothing happens. No gauges or lights turn off. Starter doesn't spin. Nothing. I can wait 5 mins and try again and it'll crank right up like nothing is wrong. Anybody have any ideas? I'm thinking it could possibly be a bad ground to the starter but wanted to see if anyone else has had this problem. And it usually does it after I've been driving for a while but again does it at random times and will start shortly after.
Old Apr 12, 2012 | 10:11 AM
2003chromefatboy's Avatar
2003chromefatboy
Had this happen last year. Somewhere in this forum is a thread about the starter selenoid up on the passenger fender under the hood. I jumped it there a few times, then went to Long Island Truck parts and bought the replacement for $12. Mine is a late 99. Good luck. Chris
Old Apr 12, 2012 | 11:19 AM
BigTruk small feet's Avatar
BigTruk small feet
^^^^^ what he said. I had the exact same problem with mine and it got worse and worse. Replace the solenoid you'll be good to go.
Old Apr 12, 2012 | 12:06 PM
oryc124's Avatar
oryc124
Thanks guys! Looks like ima be changing a solenoid this weekend
Old Apr 12, 2012 | 05:51 PM
BigAlsPSD's Avatar
BigAlsPSD
Another possibility is loose torx screws for the shifter.
Will it start in neutral?
Is your shifter sloppy?
Check out theses screws as viewed from the floor, looking up and back towards the driver's seat. They are pretty common for working loose.
Old Apr 12, 2012 | 06:40 PM
oryc124's Avatar
oryc124
Never tried starting in neutral but would move it through the gears on occassion to make sure it was in park. Ill check those screws as well. Has some slop in it but all f250s or even older fords in general I found had about the same amount of slop in the steering column.
Old Apr 13, 2012 | 02:16 AM
carltonwebb's Avatar
carltonwebb
Tighten those screws and the slop will be gone. I did my 2000 and then bought the 2001 and could not even find the gear i wanted until i tightened the screws.
OrangeRanger
May 7, 2015 01:33 PM
jpowers2069
Dec 5, 2011 09:05 PM
paddler
Dec 18, 2010 06:41 PM
greg240
Apr 19, 2004 05:37 PM
EdTroy
1997 - 2003 F150
13
Jun 9, 2003 06:36 PM
