1998 Expedition transmission coolinglines leak
Hi all,
So my transmission cooling lines were rubbing together and are now leaking.
Was looking to replace them with new ones but cannot quite determine the right part number.
Does anyone here have any info on this ?
1998 Expedition built May 1998 with 5.4L and 141k miles.
Thanks in advance
Pep
Thanks in advance
Pep
You could cut out the leaking section or sections.With a tubing cutter. Replace the sections with the rubber transmission line that will slide over the steel tubing. Double clamp each end with the screw tighten band clamps. (use 2 each end) Wire tie the lines together so they can't move. Check the lines from time to time to make sure they are not leaking. The clamps can rust out and fail. Spray them with WD40 / PB Blaster ect to protect them.
Autozone sells them,atleast without the aux trans cooler setup. Bought the set of lines for my 98 last fall, if they have stopped selling them since then, then you are right.
I guess from my earlier post, they can get them for both aux and regular style coolers.
fitzy67
1997-2006 Expedition & Navigator
05-11-2019 12:25 PM
mystang89
08-31-2017 09:19 AM
DOC1KOC1
12-26-2011 10:45 PM
