Aerostar Ford Aerostar
Speedometer, Odometer, Cruise Control not working
Old Apr 11, 2012 | 07:46 PM
whatdayasay's Avatar
whatdayasay
My speedometer, odometer & cruise control quit working and I think the transmission overdrive is also not working on my 95' Aerostar 2wd, 3.0L engine. I replaced the speed sensor that sits above the rear differential, but that didn't help. i wondering if something needs to be reset? Help!
Old Apr 11, 2012 | 11:29 PM
asavage's Avatar
asavage
FTE Community Team
If you've replaced the speed sensor in the diff, I think you'll need to troubleshoot the PSOM (Programmable Speedometer/Odometer Module) next. Hopefully, someone will come along and explain that, as I've never had to play with it. You might try searching this forum for that term.
Old Apr 12, 2012 | 05:59 PM
96_4wdr's Avatar
96_4wdr
check the fuses. these ATCs can fool a guy, best to sub a new one.
F8 switched 12v to PSOM etc.
F17 continuous 12v to PSOM
the PSOM is mounted on a daugher board that spring contacts mounts on the dash speedo/function board behind the dash. the spring contacts do get corroded.
Old Apr 12, 2012 | 06:31 PM
asavage's Avatar
asavage
FTE Community Team
Is it that PCB with the black connector, in the center there?
(click on image for larger)
HTRDLNCN
1997 - 2003 F150
Apr 23, 2010 09:35 PM
PatchMcGav
1983 - 2012 Ranger & B-Series
Sep 14, 2008 07:27 PM
dcarnut1
Jan 5, 2008 04:21 PM
Tater0519
Apr 12, 2005 07:33 AM
randy_kanada
Electrical Systems/Wiring
Feb 16, 2004 07:02 PM
