Sea Foam Questions
Sea Foam Questions
OK so the advice on these boards has been impecable. You guys are awesome and any of you near Fort Worth Texas PM me and I'll buy the first few beers.
Now I keep reading the heck out of people saying they "Sea Foamed" their intakes and such. I went to the Sea Foam website and did some reading and now want to ask a few questions.
1. My truck is near 200K miles and doesn't leak or burn a drop between oil changes. I have always been kinda old school in the thought that adding engine cleaners to the crank case can break up more crap than you want, what do you guys suggest?
2. I add Valvaline complete fuel system cleaner to both tanks and fill em with super every oil change (3000-3500 miles). I used to love thier full synthetic line but they dropped it for whatever stupid reason. Do you guys think Sea Foam is any better in the gas?
3. Dripping it in the vacuum lines will that not dry the crap out of the lines and what are your thought on this?
I have not had any problem with the brake booster vacuum line after putting Sea Foam through it. That is the only place I put Sea Foam in my truck, not the fuel tank or crank case.
No Seafoam
I,ve had to replace the rubber on every machine I used Seafoam in. I used it in 2 motorcycles, a chainsaw & two weedeaters (Thankfully I had not put it in a car or truck yet). All the rubber in the carbs & all the fuel lines dried out and crumbled, just as if they were a hundred years old. I'll never use it again!
See foam !!!
I am NOT a believer in Seafoam anyplace !!!
I had the "old ones " tell me of a story passed down thru the years... Use water sprayed in the intake ...Remove the intake hoses/air cleaner ( for carb equipped cars N trucks) get you garden hose down to a fine mist/spray... when the motor is at runnung temp, rev the motor at around 2500-3000 RPM then feed in the water, being careful NOT to let it die... I did mine for around 10 min. ... remove water ... let it idle... it should dry it self off quickly. Re-attach all the intake stuff... then drive, it should be much smoother. If you feel it could be smoother... do it again !!! REMEMBER the motor and converter MUST BE HOT !!! CAUTION If you use too much water, not likely, you could hydro-lock ... "lock up" the motor NOT GOOD!!! Dave
"No baby seals will be harmed with this product"
I add a can of seafoam to each of my vehicles tanks twice a year. Never have had any problems. I wouldn't put it in my oil but thats just me. I have also used the water trick in our 78 CJ5, I have to admit I was not to sure about it, but it cleaned it out and she is running nice and smooth now.
In the tank stuff
The best results from any product I've used is from BG products. It is a dealer only or shop use. The last place I found it was at a BIG O TIRE STORE
in the mean time about every month or so, I dose each tank with the small bottle of Lucas ... been doing that for about 2 yrs... kept my Hi-way MPG close to 14 and city was 12.5 max.
After I did the 6 Liter tune, combo MPG IS 14.47... I feel a road trip coming !!!
Dave
Dave
DISCLAIMER: No, I don't work for BG or have any interest in the company.
dieselsndoggies
08-03-2014 06:01 PM
97redf150
1997 - 2003 F150
12-20-2004 12:53 AM
