Seafoam Questions
It is probably just coincidence, but I had a an few extra bottles (I purchase 5 or 6 bottles at a time as I normally fill up the boat in the morning close to the lakes I am fishing) sitting in the back of the Expy and I decided to add it to the trucks fuel (through the fuel fill), and the next morning my truck failed to idle and would just die after starting unless I used the gas pedal to keep it running. This is the first problem I had with my Expy..and you don't forget your first
. The garage replaced the sensor and it hasn't been a problem. I still add it to my fuel, but once every 6 months, I haven't actually seen it do anything in my truck, but I "imagine" if there is any moisture build up this stuff that has worked so well on my other motors can't be too bad in my Expy. . I'm not a mechanic…and I even reported a problem that I associated to bad gas, and it took a transmission reconstruction to fix the problem…should have added it to my transmission (just kidding)
.I don't believe in a "Fix-it-all-product" and I have never used it for anything but in my fuel system (adding it to the gas), but I have read the label and it appears you can add it to just about every where (crank case, etc).
I add it to my fuel/Oil mixture on my Mercy 175+Hp outboard motor, and noticed better idling (which is important to prevent the motor from dieing on me-when I pull into a boat slip and don't want to run into the other end
when I put it into reverse to stop forward motion ). When I had a smaller motor (120HP) on the same boat, I noticed a the best top end speed of 33mph, when previously I was only able to get 31. So I am a firm believer in this product… just too bad I can't get it at Wal-Mart, as I always add it to my boat's fuel system.I had some problems with my lawn mower engine (not running soothly..rev up, rev down), and I added a few caps full to the tank, and it ran perfectly. Although, when I store the mower in the garage and not empty the tank, there is a much stronger 'gas smell' (so it is doing "something" to the fuel) permeating in the garage.
2001 Ford Expy XLT 4x4 with 133K miles on Engine and 321 miles on reconstructed transmission (79 more miles to go and I'll be able to tow my boat again)
Hope that helps
