Interior LED problem maybe
Old Apr 10, 2012 | 11:31 PM
bleedford's Avatar
bleedford
i have had my blue interior LEDs installed for a week now, and tonight was the first time i noticed that when all the doors are closed and the lights should be off they are still on. it is not at full brightness, just enough to see that they are still on faintly. is this normal? *it is only the two front ones*
Old Apr 11, 2012 | 10:41 AM
04XLTRUNNER's Avatar
04XLTRUNNER
My backseat light used to do this on my 2009. It because the leds dont consume as much power as a regular light. It will eventually fade out. I noticed sometimes I could see mine for as long as 2 hours before it finally went completely out. It wont hurt anything. The lights dont pull enough to drain a battery
Old Apr 12, 2012 | 01:57 AM
Southpaw666's Avatar
Southpaw666
I haven't noticed this with mine, I've only had mine in for 2 days however, I will try them out and post back if they do the same.
Old Apr 13, 2012 | 12:22 PM
Southpaw666
I would say this is not normal, have you tried re-seating the bulb? I had to adjust the bulb clamps a bit for mine to seat properly. Mine go out right after the fade when I lock the truck.
Scott51
Sep 14, 2016 12:29 PM
BroncoRN
Oct 5, 2012 04:45 PM
MDSuperDuty
Jul 1, 2011 09:27 PM
Avnchief
Mar 29, 2010 08:25 PM
