newbee.. first post can someone decode my data plate?
Old Apr 10, 2012 | 11:02 PM
mylockerx's Avatar
mylockerx
F11yrx41720
117 A. F110. D. 4. A. 05J.
05250. 1975. 74.
thank you any help would be greatly appreciated.
Old Apr 10, 2012 | 11:04 PM
ChiefM's Avatar
ChiefM
This should help you out:
Decoding '73-'79 Ford Truck VIN Tags - FORDification.net
And welcome to the Forum !!!!!1
Old Apr 11, 2012 | 05:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
newbee.. first post can someone decode my data (Warranty) plate?
Originally Posted by mylockerx
F11YRX41720 / 117 / A / F110 / D 4 / A / 05J / 05250 / 1975 / 74
Welcome to FTE
There is no need for you to go elsewhere to decode this jazz.
F11 = F100 4WD Pickup.
Y = 360 2V
R = San Jose CA Assembly Plant.
X41720 = 1975.
117" Wheelbase.
A = Raven Black.
F110 = F100 4WD Pickup, 5,250 lbs. GVWR
D 4: D = Black all Vinyl // 4 = Styleside Pickup.
A = New Process 435 4 Speed Manual Transmission.
05J: 05 = Ford 9" Rear Axle / 4.11-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity // J = Power Steering.
5,250 lbs. Gross Vehicle Weight Rating.
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
Note: Three day Portland Car/Truck Swap Meet (April 13, 14 & 15 2012) / Held at the Portland Expo Center adjacent to the Columbia River.
The is one of the best swap meets in the US (portlandswapmeet.com).
Consider joining FTE's WA Chapter. You'll meet a lotta nice people, attend GTG's and will receive local help when asking for advice and etc.
Old Apr 11, 2012 | 06:15 AM
ChiefM's Avatar
ChiefM
Thanks bill,
Was going to decode last night but got busy doing army stuff
Old Apr 11, 2012 | 06:18 AM
NumberDummy
Thank you for serving.
I looked at the OP's profile, it says 1976 F100. I wonder if this is a different truck or if the left door on this truck is the original?
When OP posted Warranty Plate codes, the year code he typed is 1975. Last 6 digits of VIN decode to 1975, so 1975 isn't a typo.
OP: Compare the VIN on the Warranty Plate with the VIN on the registration to see if they match. If they don't match...
Peeps replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plate on the replaced door.
If this is the case, you can contact martiauto.com, pass along the VIN on the registration. Marti (for a fee) will send you a copy of your trucks original build sheet.
Marti can also supply you with a new Warranty Plate that will have the correct VIN and codes stamped on it.
Marti has ALL the FoMoCo records that apply to 1967/79 vehicles, FoMoCo has none of it anymore.
In the late 1980's, FoMoCo was planning to THROW AWAY all these records. Kevin Marti, a Mustang 'nut' in Phoenix AZ found out, and got ALL of it!
Jared96f150
Dec 12, 2014 09:08 AM
diesldoct
Apr 25, 2014 12:05 PM
Phreezerburn
Aug 12, 2012 11:27 AM
ffflash480
Aug 17, 2011 11:10 PM
Herky737
Oct 20, 2010 06:40 PM
