Ideal tire pressure?
Old Apr 10, 2012 | 06:15 PM
jayjjcc's Avatar
jayjjcc
All my stickers on the truck telling me the recommended tire pressure are worn out... I'm running Michelin LTX M/S 265/75R16 "E" rated tires.
Max tire pressure on the sidewall says 80psi. They're at 30psi right now (old owner had them down alot for winter and I had not checked them yet).
I'm not looking for comfort and I do not load it up or tow... I just want the best MPG possible with most even treadwear!
2000 4x4 v10 btw
Old Apr 10, 2012 | 06:38 PM
ScaldedDog's Avatar
ScaldedDog
The stickers say 50 for the front and 55 for the rear. That works fine, but is a little soft for my tastes. I usually run 55 and 60, unloaded.
Mark
Old Apr 10, 2012 | 07:02 PM
Snowseeker's Avatar
Snowseeker
Mine are at 70 front and 80 rear all the time.
Old Apr 10, 2012 | 07:05 PM
jayjjcc's Avatar
jayjjcc
Does diesel vs. v10 make a difference? Why higher in the rear than the front?
Old Apr 11, 2012 | 03:45 PM
dosecobanya's Avatar
dosecobanya
I've always heard to fill to what the tire reads not what the truck reads. Isn't that what got ford and firestone to part ways?
Old Apr 11, 2012 | 05:36 PM
ScaldedDog's Avatar
ScaldedDog
Diesel vs. V10 - Maybe, but you'd have to compare stickers to know. The numbers I gave above are from an '01 PSD 4x4.
Sticker vs. Tire - The sticker shows the pressure required to support each axle's weight rating with the OEM tires. They can be wrong, I suppose, and I generally prefer the ride with a little more air than the sticker says, but that's a personal preference. The tire shows the max weight rating of the tire, and the pressure required to archive it. There's no reason to run that max pressure unless you are putting that much weight on each tire, or just like a really hard tire. When I've done that, even when towing, I found that the front end felt really light on wet roads.
I run 60/70 on E-rated tires when towing, and I'm just under the max legal weight rating of the vehicle.
Mark
Last edited by ScaldedDog; Apr 11, 2012 at 05:53 PM. Reason: Can't type on tablet...
Old Apr 11, 2012 | 07:28 PM
Snowseeker's Avatar
Snowseeker
Tire pressure has a big effect on tire wear as well. Lower tire pressure also causes more heat in the tire.
Old Apr 11, 2012 | 08:02 PM
aortizexcursion's Avatar
aortizexcursion
diesel vs. v10...diesels weigh a hell of a lot more than a V10. Therefore, the front tires on a diesel should have more air than the front tires on a V10
Old Apr 11, 2012 | 08:06 PM
aortizexcursion
I run 60 front and 70 rear.
Old Apr 11, 2012 | 09:35 PM
WE3ZS's Avatar
WE3ZS
^ This. Heat kills tires. I ran my Silent Armors at 80 PSI all the time for 20k miles and have seen dead even wear and they run very cool, less than 10 degrees above ambient temps.
Old Apr 11, 2012 | 09:54 PM
aortizexcursion
I run higher in the rear because my Excursion is heavier in the back than it is in the front. I have a 2WD with the 5.4 which makes for the lightest possible front axle weight on an Excursion. On the other hand, A 4WD diesel Excursion is probably going to be heavier in the front; if that is the case, I would have a slightly higher amount of air in the front than in the rear if you are going to be driving around with no load. If you add a load to that 4WD diesel though, the rear will again be heavier and the tire pressure will have to be adjusted to compensate for that change.
Old Apr 11, 2012 | 10:26 PM
Forest's Avatar
Forest
I run 65 psig front/rear when not towing. When towing our big trailer, I run 80/80 psig. Actually, if I don't want to mess with it and think I'll be towing again within a week, I just leave it at 80/80 psig. 80 is a bit stiff, but the big Michelins are still pretty compliant, even after 50,000 miles.
Old Apr 12, 2012 | 12:26 AM
EXv10's Avatar
EXv10
Why is the ex (v-10) heavier in the rear when then engine is in the front? Also; FYI 80lbs on an E rated is where the tire is at it's strongest.
Old Apr 12, 2012 | 07:03 AM
Snowseeker's Avatar
Snowseeker
A fully assembled sterling 10.5" rear end I bet is about the same weight as a V10 or 5.4.
The other heavy things are 44 gallons of fuel, lots of seats, heat and A/C in the rear, spare tire, and all kinds of metal, glass, carpet, sound deadening, and stuff.
Plus the front tires are closer to the front of the truck then the rear tires are to the rear of the truck. Just the tire positions put more weight on the rear wheels.
Old Apr 12, 2012 | 10:39 AM
EXv10's Avatar
EXv10
I think it is the placing of the wheels. Gas isn't always full, rear end isn't that heavy duty, other SUVs are equipped the same, and it is 4wd also.
