A fully assembled sterling 10.5" rear end I bet is about the same weight as a V10 or 5.4.
The other heavy things are 44 gallons of fuel, lots of seats, heat and A/C in the rear, spare tire, and all kinds of metal, glass, carpet, sound deadening, and stuff.
Plus the front tires are closer to the front of the truck then the rear tires are to the rear of the truck. Just the tire positions put more weight on the rear wheels.
65/65 here, but I am running 285/75-16's. I agree with Snow on weight. I also read somewhere that the PSD weights 700 lbs vs the v10 at 400 lbs +/-.
TrdLtly, what does your sticker say about tire pressure? The PSD is heavier, for sure, but I bet the front axle rating is the same, and so would be the recommended tire pressure. Can you take a look and prove me right, or wrong?
Mark
PO peeled the door decal and so I can't read any of it. It got scrambled. Some else will have to give input on that. I had a picture of my '04 F350, but can't find it.
A few months ago, I took the Excursion to the scales and she weighed at 6780lbs with 3200 lbs in the front and 3580lbs in the rear. Like I said, I have a 5.4 2WD. It is likely that a 4WD diesel would bias the weight distribution A LOT to the front. And I agree with everything Snow said.
Do you know how much fuel you had then? I agree with a diesel and 4wd it would be more weight on the front than back. With your numbers I would think like my 2wd diesel it is pretty even front and back. Personally I run the lower pressure in the front because it dampens the road from the steering a bit. 80 in the rear I guess because I tow stuff all the time plus I always have about 200 pounds or more of stuff in the back.
I weighed my 4x4 PSD, as well, with a full tank: 4240/4000.
But you have a small engine and 2wd, what would a v-10 4wd be?
They're at 30psi right now (old owner had them down alot for winter and I had not checked them yet).
you might want to consider getting rid of those tires
if the prior owner drove on them alot, the sidewalls are likely damaged. that is too low a pressure for the weight of an X.
Read up on the Exploder/Firestone incidents 10-12yrs back. People were driving with low tire pressures in hot weather. it caused the tire to delaminate and faile
I personally would start at 50 psi in the tires and go from there. Just monitor tread wear and adjust as necessary. The door stick is utterly useless now anyways. It is only worth a darn when running the exact same tire and size as the X came from the factory.
