Replace A/C compressor
Old Apr 10, 2012 | 04:23 PM
nomad221's Avatar
nomad221
Compressor finally quit after 159K. Could an A/C guru please educate me as to what all is involved with installation of a new one ? I'd like to get a couple of quotes from some local shops and do not want to get burned, or, if I can, replace it myself.
Old Apr 10, 2012 | 07:22 PM
ReBilld's Avatar
ReBilld
Is the compressor shot? I've never done it, but you can put new clutches in it.
Old Apr 10, 2012 | 07:35 PM
nomad221's Avatar
nomad221
The hub engages but the compressor shaft will not turn. Hub is burned up now.
Old Apr 10, 2012 | 07:46 PM
ReBilld's Avatar
ReBilld
You could replace the compressor yourself, it's not a bad job, but if the system is still fully charged you'll have to have it evacuated before you unhook the manifold at the compressor. Then, unless you have access to a vacuum pump and gauges you'll have to take it some where to have a good vacuum pulled on the system and recharged after you replace the compressor.
rickfar
Escape & Escape Hybrid
Apr 15, 2011 09:18 AM
NeXtras
15
Mar 25, 2007 11:09 PM
RangerMikey2u
Jul 14, 2003 08:16 PM
