How to test* Resolution
Old Apr 10, 2012 | 04:18 PM
2FordTrucks's Avatar
2FordTrucks
I try to make it a point to come back and post my resolutions when I ask about a problem. Mine was one of those misfire issues that would not throw a code. So after spending a bunch of money at the shop and getting no solution I brought it home and started actually troubleshooting. I guess it is a lost art at repair shops.
I pulled the fuel rail to find one injector missing the top o-ring. I was like WTF!!!! The #8 cylinder had a misfire. The missing o-ring was on #5. I replaced both #5 and #8 injectors and still got no relief. My next step was to replace the buzzing motorcraft pcv valve. Nope, did'nt do the trick. I then replaced the motorcraft platinum plugs with new motorcraft platinum plugs on that entire bank and so far so good. I'm thinking after they did thier service and replaced the plugs the faulty injector gassed the new plug. That pointed them to COP's. I took it back from them at that point. So, 120 miles later it is getting the best mpg I've seen 16.6 on the interstate coming home and pulls like normal. The idle is a tad rough but it was like that for a while. I need to replace the ratty exhaust on it and I'll clean the MAF sensor and the K&N as it is time. Thanks to all for sticking in there and helping me along.
Old Apr 14, 2012 | 07:25 AM
JWA's Avatar
JWA
Check your IAC---unless that's already done and its working properly?
(Didn't re-read your previous thread on this issue---sorry if this is redundant!)
69ford99
2004 - 2008 F150
Dec 16, 2010 07:10 PM
greenexpy
Modular V8 (4.6L, 5.4L)
Jun 29, 2008 02:42 PM
rouschfan
1983 - 2012 Ranger & B-Series
Apr 28, 2008 05:32 PM
jjlrrw
1997 - 2003 F150
Aug 21, 2006 08:34 PM
myke
1997 - 2003 F150
Feb 7, 2005 04:45 PM
