c6 transmission question.
Old Apr 10, 2012 | 01:43 PM
azaeldrivesford's Avatar
azaeldrivesford
I have a ford f250, 1986, 7.5, (460) 2wd. I went to replace the transmission modulator valve and when I took it out trany fluid came pouring out, when I looked up how to replace the valve no one said anything about needing something to catch fluid in.
Is this supposed to happen or do I have a bigger problem then a bad modulator?
Old Apr 10, 2012 | 01:51 PM
82f100460's Avatar
82f100460
nope...you will get fluid out for sure.
As you have found by know, they go in and out pretty easy. I just put a little pan to catch the fluid. Have the new one ready and plug her in there as quick as you can. Not a whole lot will come out but try to minimize it.
Old Apr 10, 2012 | 03:15 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Yes, fluid will drain out when the modulator is removed. Just don't forget to pull the pin out of the old one, and insert it into the new one prior to sticking it in place.
You oughta see the mess that happens when the modulator isn't secured properly, and it pops out while driving down the road......... Been there, done that.
Old Apr 10, 2012 | 03:17 PM
82f100460's Avatar
82f100460
Yes...the rod!!! So when I say swap it out quickly....not too quickly
Truxx1956
Aug 10, 2008 06:29 PM
Metdawg44
Jan 16, 2008 12:23 PM
ubahd00d
Feb 24, 2007 06:27 PM
buzzard
Oct 15, 2005 04:29 AM
fordiesel69
Sep 24, 2001 03:21 PM
