need help fast
Old Apr 10, 2012 | 10:27 AM
pikafall96's Avatar
pikafall96
need help fast
Stuck on the side of the road! Have an 2004 F-250 4x4 6.0 that keeps shutting off.... just changed the alternator last week and now it runs like ****. Please help! Call if you want. (956)346-3278 only have 107k miles. Oh and i changed oil and replaced fuel filters too, two weeks ago. Right now it cranks fine, sounds fine for 20 seconds and then shuts off. Took me 8 cranks to move into a parking lot.
Old Apr 10, 2012 | 10:51 AM
Furian's Avatar
Furian
You Keep What You Kill
BUMP!!!!!!!!
Old Apr 10, 2012 | 10:58 AM
powerstroke72's Avatar
powerstroke72
I've moved your thread to the 6.0L Powerstroke Diesel forum where you'll hopefully get faster assistance.
Old Apr 10, 2012 | 11:00 AM
pikafall96's Avatar
pikafall96
Not sure what bump means. My friend says be had the same problem and it was the high pressure oil pump
Old Apr 10, 2012 | 11:11 AM
powerstroke72
The "bump" means he was posting in order to shove your thread back to the top of the forum in order to keep it from being buried by other threads so you'd hopefully get help more quickly.
Old Apr 10, 2012 | 12:01 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Can you get some codes read?
Check wires from alternator.
You used OEM filters?
Did you notice the oil pressure gauge?
Have any way to check sensors?
Old Apr 10, 2012 | 12:25 PM
pikafall96's Avatar
pikafall96
Pulled it to the shop and now the batteries are dead. Gauges are acting funny and it won't turn over. Hooked up the code reader and nothing. About to unhook the banks 6-gun tuner and see. Even my mechanic is scratching his head .. If it was an old animal it would need a bullet in the head. .....OK, now it turned on and ran for 20 seconds and then crapped out.
Old Apr 10, 2012 | 01:57 PM
Snuggyworm's Avatar
Snuggyworm
both batteries need to be at 12v. sounds like u had bad batteries situation earlier that killed ur alternator. my next move would be to check ur ficm voltage.
since u had such a bad case, it is possible tat ur ficm could have been killed in the process. still, check our tech folder and follow the testing procedure for ficm voltage. ur ficm should be located under the degas bottle.
u will see a heat-sink looking thing underneath tat. best of luck.
Old Apr 10, 2012 | 01:59 PM
Snuggyworm's Avatar
Snuggyworm
btw, if ur batteries died earlier, then the car's memory to store the codes probably got erased. if u hook on new batteries, it'll take a bit of driving before the codes come back again. i tink it has to be between 30 to 50 miles b4 the codes come back, and tats also if it's inherent.
Old Apr 10, 2012 | 02:08 PM
pikafall96's Avatar
pikafall96
I unhooked the six gun and now it's running fine. We'll see what happens now. Thanks
Old Apr 10, 2012 | 11:32 PM
Piolet's Avatar
Piolet
https://www.ford-trucks.com/forums/1...ch-master.html
Keep this thread in the back of your mind incase it happens again. Problems like chaffing, or shorts in the harness can cause these unpredictable and random shut-offs.
Old Apr 11, 2012 | 01:14 AM
Snuggyworm's Avatar
Snuggyworm
best of luck, pal! i hope that may have alleviated the problem at the very least. i dunno. maybe ur tuner is the prob?
seijirou
Jan 2, 2017 05:36 PM
Brittany Gossett
Jun 7, 2012 07:57 PM
2000V10USER
Mar 18, 2011 07:00 PM
shiftyblack
Dec 5, 2010 10:03 PM
Roy Morgan
Jul 25, 2010 09:44 PM
