06 6.0 doesn't start suddenly
Old Apr 23, 2012 | 09:58 PM
  #31
bpounds's Avatar
bpounds
Originally Posted by GeneLaw1
Not sure if this is really relevant but I thought I might mention it here because I have never really had this happen. After an unseasonably cold evening in Atlanta last night (50s) an hour ago with a good "cold" engine I chose to try to start the truck see what would happen. I let the glow plugs do what it is that they do and cranked it. The truck started almost IMMEDIATELY! There almost no "build period" as it started with a second or two. WT was at about 57 when I tried to start....does this have any relevance here?
From post #7 above.
Originally Posted by bpounds
Leaks in the HPO system can come and go. The problem is temperature sensitive, but that is not the only issue. O-ring seals squirm around in the seat more than you might think under the high pressures seen in this system. This results in erosion of the seals. I've seen them with big grooves worn in them. But because they squirm around, sometimes they leak, next time they don't.
Old Apr 23, 2012 | 10:21 PM
  #32
BLADE35's Avatar
BLADE35
Very well put Bill
Gene Intermittened problems suck they can be some of the worst to figure out Especialy Electrical issues
Worst case senerio here if it Bugs you too bad IMO its pretty safe to say Low ICP points to the HPO System so being you have an 06 its pretty safe to say you will need STC Fitting and standpipes and dummey plugs sooner or later so you could change them and you will be ontop of the Game those kinda seem to go out between 60-80K miles. And maybe you have already addressed some of those IDK throwing it out there. the above mentioned parts are not IF but WHEN will they go
If it was ICP or IPR those failing would be more Constant problem IMO I could be wrong as things dont always Fail the same way. But if it did turn out to be ICP sensor If you can change a Light Bulb you can change your ICP sensor.
Now the IPR is a diffrent storey here just alittle harder to get at but the right tools make all the diffrence in the world
Old Apr 25, 2012 | 12:39 PM
  #33
GeneLaw1's Avatar
GeneLaw1
Originally Posted by BLADE35
Very well put Bill
Interstingly enough, from what happened to me today, you and Bill are right behind this problem. I went to breakfast this morning and parked on a steep hill, nose down. Came from eating, truck still fairly hot (about 150) and wouldnt start, at all. ICPs were in the 150 - 160 range while starting!! NEver been that low, usually in the 300s at least. My father who was with me suggested rolling it down the hill to level ground...fired it and it started right up.
Old Apr 25, 2012 | 01:05 PM
  #34
GeneLaw1's Avatar
GeneLaw1
Is there some sort of test the dealer can do on the HPO system to determine exactly what it is leaking in there? I want to go in there with some knowledge instead of just saying "find out why it wont start sometime" haha...they will see me coming a mile away
Old Apr 25, 2012 | 01:54 PM
  #35
bpounds's Avatar
bpounds
Yes, there is a shop air test. Consists of removing the ICP sensor, and using an adapter to connect a compressed air line to pressurize the HPO system. Then using a 12volt source to force the IPR closed. Then listening for leaks on the left, right, and back center. If the leak is big enough, you can hear the air escaping. For smaller leaks it might be necessary to remove valve covers and actually look for the leak path. The smaller leaks tend to be slow-start cases, while the larger leaks tend to be no-start cases.
There is plenty of discussion on all this in the tech folder threads. You can even do the test at home if you want to pick up a few bits and pieces.
Old Apr 28, 2012 | 01:44 PM
  #36
GeneLaw1's Avatar
GeneLaw1
Great info. I have setup an appointment with the local dealer next Wednesday to do their Diag. My hope is they can actually re-create the problem. I am going to give them all the information I have logged and gotten here and see what they come up with.
Old May 3, 2012 | 01:34 PM
  #37
GeneLaw1's Avatar
GeneLaw1
Just an update, and to solve the conundrum, the tech has told me he believes it to be the Pump. After doing the leak test, he noticed no air leaks on my HPO system. Also with the symptoms and it being so erractic, says it all points to the HPOP.
Old May 3, 2012 | 02:29 PM
  #38
bpounds's Avatar
bpounds
Well, if you're asking for opinions - I don't believe it.
Old May 3, 2012 | 03:04 PM
  #39
GeneLaw1's Avatar
GeneLaw1
Def not surprising, but as you said earlier to avoid "dancing in the minefield" I am going to just replace everything we spoke of. plugs, STC and the pump, call it a day to the tune of around $1400.
Old May 3, 2012 | 03:10 PM
  #40
bpounds's Avatar
bpounds
To include the pump, that is a good price.
Old May 3, 2012 | 05:23 PM
  #41
GeneLaw1's Avatar
GeneLaw1
THATS WHAT I SAID! According to him, the pump itself runs around $900. I should be picking it up tomorrow...
Old May 8, 2012 | 03:38 PM
  #42
makeone3's Avatar
makeone3
My 6.0 started surging etc. Code eventually showed up and indicated ICP failure. Also noted that one 6.0 owner said he had replaced his ICP three times in one year. Well three times indicates something else is causing the problem. My 6.0 has the ICP and IPR on the back of the engine is a bear to service. So while I had it apart I replaced both sensors and why not! The Ipr could be leading to a lot of the ICP failures. O by the way my truck is now running great.
jiveturkey692000
Nov 20, 2013 12:58 PM
Iaff113
Nov 15, 2012 07:43 AM
canadianstroker
Jan 12, 2012 08:34 AM
bigbadwolfe
Oct 21, 2011 07:03 PM
dougbrown
Dec 22, 2010 06:16 PM
