1978 - 1996 Big Bronco
exhaust
Old Apr 9, 2012 | 06:35 PM
cajunsf's Avatar
cajunsf
exhaust
is there a route for exhuast on the drivers side of a 92 with a 351?
Old Apr 9, 2012 | 09:07 PM
critterf1's Avatar
critterf1
Single or dual tanks? 2 or 4 wheel drive?
Old Apr 9, 2012 | 10:05 PM
NewEnglander's Avatar
NewEnglander
Dont think so, driveshaft and transfer case is in the way. I think to do dual exhaust everyone runs both pipes down the passenger side.
Old Apr 11, 2012 | 02:05 PM
Edgethis's Avatar
Edgethis
Every US made Bronco was 4 wheel drive and had only one tank. Only known exceptions are some South American Broncos were offered with 2wd and the Centurion conversions which were based off of F250s
Basically no you cannot run true duals down both sides of the truck. It is possible to run both pipes down the pass side as NewEnglander mentioned.
Old Apr 11, 2012 | 06:48 PM
greystreak92's Avatar
greystreak92
Driver's side is a bad idea anyway. You get closer to high pressure fuel lines, filters and electrical harnesses down the driver's side of the truck. Not exactly the kinds of components that are friendly with exhaust systems. I'll chime in here and agree with NewEnglander's suggestion to keep to the passenger side and if you want to run two pipes, just run them side-by-side and don't forget the cross-over pipe between them.
blackdogridge
May 26, 2008 02:13 PM
smallblock351w
May 1, 2006 07:33 PM
STANGIN
Dec 10, 2004 01:41 PM
kermit
Feb 11, 2004 02:34 AM
BIGR3D94
Apr 3, 2003 06:51 PM
