dual exhaust
Old May 1, 2006 | 12:28 PM
smallblock351w's Avatar
smallblock351w
dual exhaust
looking for opinions, getting ready to run 2 1/2 true duals on my truck tomorow with flowmaster super 40 series mufflers, i cant decide to run it out in front of each wheel or behind. I know it has the side tank so it will be a little tougher to run it out in front of the wheel on the driver side but my dad has the pipe bender since he bends custom exhaust. Any opinions would be very appreciated
Old May 1, 2006 | 04:10 PM
mgraveman's Avatar
mgraveman
I never liked this arrangement. When you split the exhaust, you have an effective four cylinder out each side. It hink this sounds very bad when driving next to someone. The exhaust sounds much better if they both come out the smae sinde, in my opinioin.
I have mine both going over to the passenger side, and exiting right behind the rear tire.
Old May 1, 2006 | 04:29 PM
travisd's Avatar
travisd
I ran mine straight out the back. The only negative about that is when you're loading stuff right after it started the pipes will blow condensation on your pant legs, but ain't such a big thang.
Old May 1, 2006 | 04:33 PM
Kemicalburns's Avatar
Kemicalburns
make sure you install a crossover someplace. this is over looked often and if you dont get it will hurt performance. is this 2wd or 4wd truck?
Old May 1, 2006 | 04:40 PM
smallblock351w
its 4 wheel drive
Old May 1, 2006 | 05:22 PM
ol gray mare's Avatar
ol gray mare
Im running mine out the back not for looks but just because it was less bends.
Old May 1, 2006 | 07:07 PM
jinserra's Avatar
jinserra
I'm still thinking about how to run mine. I'll probably run both of them out in front of the back tire on the passenger side. I want to run them one on each side but am too lazy to get the pipes bent and hung.
Old May 1, 2006 | 07:33 PM
smallblock351w
well im having them bent and i really awnt them out in front of both back wheels but its tough getting around the drivers side side gas tank. kinda afraid the pipe would hang to low
