Maybe injector problem?
Old Apr 8, 2012 | 10:19 AM
95PSDieselP's Avatar
95PSDieselP
well i bought y 2003 f-250 6.0 a little over a year ago. i have had a lot of power for a long time. but now for some reason it seems i have no power for anything....
Things i have done to it.
I replaced fuel filters, air filter (Blue Mesh), cleaned EGR Valve, replaces egr coolant to coolant hose, little blue one, Took off muffler and cat... then welded cat back in due to emissions... , use diesel 911,,,
what should i be doing to keep up the maintenance on this thing? i am sorry if this si a stupid ? but i am at a loss and cant afford for it to break down on me for not taking care of it. Please help me
Thank you for the help
Old Apr 8, 2012 | 12:54 PM
69cj's Avatar
69cj
Are your fuel and oil filters OEM? When was the oil last changed? Have you checked the ficm voltage cold, during a start and after warmed up. What is your battery voltage after all night cold soak with the key off prior to starting and during starting? Do you have any codes?
Old Apr 8, 2012 | 01:26 PM
pmoney1983's Avatar
pmoney1983
Also check the oil filter cap and ensure that its OEM as well.
Old Apr 8, 2012 | 02:47 PM
BLADE35's Avatar
BLADE35
any gauges?????????????
Old Apr 8, 2012 | 10:08 PM
Roasted7's Avatar
Roasted7
Check FICM volts first. Must be 48V-45V. No less.
Old Apr 10, 2012 | 04:48 PM
BobsF350's Avatar
BobsF350
All the time or just when cold.Does it run fine when its warmed up?
speakerfritz
6.4L Power Stroke Diesel
Dec 2, 2016 04:30 PM
ppc
Nov 21, 2012 06:43 PM
scameron
May 7, 2012 12:25 PM
mblanken881
Jan 17, 2012 09:27 PM
runningarends
Oct 13, 2009 01:11 PM
