Great reads there, 4-inch. Money I thought I needed to spend on a hpop, just might be for clutch now, and be done with it. Like someone mentioned, get in there only once, and be done, cuz its a heavy pig.
Links perfect Neal...thanks. some assurance with Whim stating...very easy job. In 1pic, looks like its the infamous clutch fork? If so, is that replacable with trans still intact?
I've put 40k on the clutch. P.O. installed one, not sure when though. Chef, u say throwout, isn't same as the pilot, or located in same spot?
No, I believe the Pilot bearing is on the end of the trans shaft when it go into the crank shift, It keeps it alined. You install it in the crank. Throwout bearing is on the fork, it presses on the pressure plate.
Chet
Gonna see if wifes' phone can video, and upload the sound at idle, along with the sound from 13-1800rpm..resonate sound, its just awful. Thing "spongebob" gots a familiar ituation.
Bonanza, so the pilot bearing is behind the rear main seal, on the motor!! This "project" sounds like its goin south
Deluxe, the ATV stand would be a good "universal" stand, considering i got a few quads here.
Haven't pulled one out on the 7.3 but it is really like bushing. The end of the out put shaft goes in it. They usually don't go pad unless you have trans problems. Thowout bearing should always be replaced with new clutch install.
Chet
Hey Chet, i know you gotta few things todo on ur truck, along with myself. I'm sure there's a few other "local" so-cals here that have things taking room on the workbench. If only one of us hadthe land to throw a So-Cal get together???
Great idea Timmy, But I don't even with the 1/2 ac., Its pretty full with my work stuff and wifes horses and all. If any body out there has the room, Its a great idea. I'm suppost to go to Morgan Hill tomorrow, but with this crazy weather I mit just stay home.
Chet
Found another thread exactly to whats goin on with mine (here). Can the inspection plate be removed w/out draining the trans or needs draining? Think i shouls stop messing around and make sure/see whats goin on in there..debris..etc. Not sure i want the trans split, if its the pilot bearing, or whatever bearing ,that then, can take out the input shaft...
pilot bearings job is to support & alighn imput shaft from trany to the center of crankshaft of engine. the throwout bearings job is to diengage your clutch by depressing the fingers on your pressure plate .
