electric fuel options
Old 04-08-2012, 10:06 AM
95schauf's Avatar
95schauf
95schauf is offline
I have a fuel leak on my 95. It has been leaking for awhile now and I am unsure if I want to fix it or swap to electric fuel. With stage 2s is it worth it and what is everyone running. I have seen the kits are pretty expensive so I am not sure that i wouldnt rather go with a build your own kit. Any help would be greatly appreciated.
Old 04-08-2012, 12:20 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Brain's 97 Diesel is offline
Several magazine articles from Diesel Tech, Diesel Power, 8 Lug and Diesel World of off the shelf kits like FASS, Air Dog, and XX Fuel System, do a web search. Also several people on this, and other sites, have done some version of a DIY conversion, do a site search.
There are very complete high $ DIY and some very minimal low $ DIY. There is one called a low buck electric fuel or something like tight wad mod.
Old 04-08-2012, 01:12 PM
97-psd's Avatar
97-psd
97-psd is offline
there are several ways to build your own system. depending on what you want you will be looking at somewhere between $400 and $600 which is not cheap but is better than buying one from someone. I really like my e-fuel, it is easy to change filters and it smoothed out the idle some.in the long run I think it was worth it because I no longer chase radom fuel leaks. I will see if I can find the threads I used to help build mine
Old 04-08-2012, 08:47 PM
FARM69's Avatar
FARM69
FARM69 is offline
I agree. I think you'd be better off making the system yourself if you have the ability to. Just do a search on electric fuel. There are several threads that have very detailed "how - to's".
Old 04-09-2012, 09:07 AM
terryknight's Avatar
terryknight
terryknight is offline
different forum but several idea here. I just finished mine. it is similar to mjonesjrs
Ford Powerstroke Diesel Forum
Old 04-09-2012, 07:48 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
Tjbeggs built his own based on many other systems. It's by far the best thread, he has Napa part numbers and everything! I book marked it for future reference.
https://www.ford-trucks.com/forums/1...-compelte.html
Old 04-09-2012, 07:56 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
I bookmarked it also. I plan on doing this in the future.
Old 04-09-2012, 07:59 PM
terryknight
it's a great mod
Old 04-11-2012, 11:01 PM
Splatts's Avatar
Splatts
Splatts is offline
E-fuel was a fun project. My DIY e-fuel has been working great. I built mine for about $600 or so. Well worth the time chasing down all the parts. It also helped me so I knew exactly how the system worked since it was my first mod to the truck. Never had a diesel prior. I used powerstroke nation and FTE to make my setup. Mainly FTE!!! I have a decent list of part #'s that I used if u need any. Good luck!!
RÖENTGEEP
27
06-24-2011 12:54 PM
ronjon95
22
03-19-2011 08:53 AM
klassik1
01-25-2005 06:03 AM
rost495
01-05-2005 11:07 AM
Quick Reply: electric fuel options
