New guy to forum needs handbrake help '49 F47
Hey guys, new to "This" forum and looking for a little help I cant seem to find on my own. My trucks original handbrake isnt working as it should, when its pulled up its not staying up and returning to its original position.
Its not clicking on the way up and and I cant see anything engaging into the gear teeth... need to get this fixed to pass safety to get it on the road. Any help is greatly appreciated.
Fully restored 49' Camaro front clip, disc brakes, etc
Welcome Aboard '49,
Good to see you working on one of these old trucks!
Pictures will also help get you some attention on here
if you don't initially get your question answered.
Our original ebrake was long gone when we purchased our 1950 F1.
We ended up putting in one from a salvage Explorer - works fine.
Good luck over there!
Ben in Austin
Ben in Austin
Ill add a pick of what the problem area is, figured we all knew what the shotgun hand brake looked like . I cant even see how that little spring would keep the hand brake in the locked posisition.
Mervy: Its hard to see the spring in the pick, but thanks for taking it.
51Panel: Ill be sure to let you know if I have to change the assembly.
parking brake pawl & spring
This is my brake lever pawl as you can see the tip is ground flat instead of having a small triangle at the end to catch the gear.
This is the pin, pawl and spring from inside the brake lever.
This is how they are together when inside the brake lever handle.
New spring just a little easier to see in the picture.
This is one of my problems the link pin from Mid Fifties is to short and is approximately 1mm to large in diameter to even fit in the original brake handle.
Looking at your picture I can see the spring is broken like merv and oldmerc said earlier.
The original had a little excess in the shaft to "squish" kinda like a hot rivet but without as much material. I popped mine out with a C clamp, a socket and a small piece of round metal that was smaller than the "rivet" If you have a Bench top vise to press it out instead of the C-clamp it would be much easier.
gdgerland
29
09-14-2007 02:36 PM
