6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
A/C Problems.
Old Apr 6, 2012 | 09:51 AM
BigSilly86's Avatar
BigSilly86
Like A Boss!
A/C Problems.
Hey my A/C stopped blowing, It still blows(cold air) a bit when I'm driving down the interstate.
Do ya'll think its the blower motor? If so how hard is it to change yourself?
Old Apr 6, 2012 | 02:22 PM
jasfaa's Avatar
jasfaa
Pull over, turn vehicle off and then back on. If it doesn't come back on then you have a different issue than I did. Mine just turns off for no reason. I have to reset something and then it turns back on. Usually happens when its hot. Damn computer controlled fan/radio/lights etc. etc.
Old Apr 6, 2012 | 02:29 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
Mine stopped blowing period. Even if I turn the truck on and of it stays off the compressor still gets cold, but it does not want to blow.
Old Apr 6, 2012 | 02:55 PM
jasfaa's Avatar
jasfaa
That sucks. I had hoped you experienced the same blower issue I did.
Old Apr 6, 2012 | 04:45 PM
Larry NCKS's Avatar
Larry NCKS
I don't know the answer to how to access the blower motor, but would bet the rest of the system is good if the compressor clutch still kicks in. Of course, with these new computerized systems . . .
Old Apr 6, 2012 | 05:45 PM
chi6488's Avatar
chi6488
You too huh?? I have the same ghost in my truck since the beginning. Dealer replaced the EATC 3 times. It still does it now but not as often. I have left it on auto mode. In the past I used the vent control settings and it happened more often.
Old Apr 7, 2012 | 08:16 PM
frdfan's Avatar
frdfan
Sounds like the AC is working but the blower motor is not, blower fuse maybe? Just a guess.
Old Apr 8, 2012 | 10:36 AM
BigSilly86's Avatar
BigSilly86
Like A Boss!
I've been researching the blower issues on my truck, I read in a few places that the blower motor resistor tends to go out. I know how to get to it but I've failed to come up with resistor failure symptoms, So I'm asking ya'll if anyone knows common symptoms of resistor failure? also anyone happen to have a fuse box layout diagram on the 6.4L? so i can check the blower fuse.
Old Apr 8, 2012 | 06:16 PM
Larry NCKS's Avatar
Larry NCKS
There's a fuse diagram in your operator's manual.
Old Apr 8, 2012 | 06:17 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
I lost my operators manual but i downloaded one off the ford website. I get in from offshore tomorrow so I'll look deeper into the A/c issue and keep yall updated
Old Apr 15, 2012 | 08:25 PM
KPBJJ's Avatar
KPBJJ
Need AC help
My AC blows cold on the passenger side but it isnt that cold at all on the two driver side vents. The same thing happens when it's cold out side and I turn it on as hot as it can go the passenger side will blow warm but the driver side never really gets as hot as the passenger side. Anyone know what might be causing this?
Old Apr 19, 2012 | 12:41 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
Found the problem, The blower motor burnt up and it also fried the resistor, I have the parts on order will replace when they get in.
ldou
Jun 11, 2018 07:30 PM
GPoff
Oct 12, 2012 12:43 PM
cardinal thunder
Aug 6, 2010 02:32 PM
KirkB
1983 - 2012 Ranger & B-Series
Jul 31, 2004 05:36 PM
dfunk77
Nov 26, 2003 10:24 PM
