2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Navigator A C problem
Old Jun 9, 2018 | 10:25 AM
ldou's Avatar
ldou
This morning I started the car turned the A C on rear came on but Front fan didn't come on. Drove down road a 1/4 mile and fan came on. Air not supper cold but works. Any
Ideas?
Old Jun 9, 2018 | 03:29 PM
gwcloud's Avatar
gwcloud
Put a thermometer in one of the outlet ducts and run the A/C full blast. In 5 or 10 minutes it should get around 40 degrees F.
Does the front fan run full speed?
Richard
2007 Navigator
Old Jun 9, 2018 | 04:39 PM
ldou's Avatar
ldou
Seems to be cycles on and off. I'm thinking it is the front blower or the switch. the compressor is running not cycleing
Old Jun 10, 2018 | 10:40 AM
alloro's Avatar
alloro
Most likely just the blower motor is bad. If it happens again tap the blower motor with a hammer and see if it starts. If it does replace it.
Old Jun 10, 2018 | 10:54 AM
ldou's Avatar
ldou
This morning I drove to town about 10 miles. blower started working half way there mde a coup;e stops and it was still working when I go home. Could a relay be the cause.
Larry
Old Jun 10, 2018 | 11:37 AM
gwcloud's Avatar
gwcloud
There are a few posts about the front blower failures here on the forum.
Here are a few causes of front blower motor malfunctions: The front blower motor resistor failure, or the ground wire that melts the insulation and the connector.
Do a search and you will see some photos.
After seeing these failures I don't allow my front blower to run very long at full speed.
Richard
Old Jun 10, 2018 | 08:21 PM
ldou's Avatar
ldou
Thanks for your help. I'll do a search. It's been working today on several trips
Old Jun 11, 2018 | 07:30 PM
ldou's Avatar
ldou
After several trips today the thing is working good, so guess I'll wait for it to act up again. Ha hopfully at home so i can work on it
SkySkiJason
21
Oct 4, 2014 02:02 PM
Polkster
Sep 6, 2014 09:39 PM
Scarny
2009 - 2014 F150
Jun 3, 2014 03:37 PM
dajst29
Sep 5, 2000 03:19 PM
