Torque value and sequence
Old Apr 30, 2003 | 12:00 AM
blssmn's Avatar
blssmn
What is the torque sequence and how much for a 300 straight 6 cylinder head? Can any body tell me?
Old Apr 30, 2003 | 12:02 AM
Mil1ion's Avatar
Mil1ion
Maybe post this question in the I6 300 engine forum.
This forum isn't for tech talk.
I'll meet you there.
Old Apr 30, 2003 | 01:33 AM
Chas1234's Avatar
Chas1234
lets see I will try and make this as easy as possible but if someone can make it easier to understand by all means post it !
11 7 3 2 6 10 14 >intake/exh side
1 2 3 4 5 6
13 9 5 1 4 8 12 >spark plug side
The numbers 1-6 are the 6 cylinders
The numbers 1- 14 are the head bolts and they are numbered in the correct sequence
Torque them in 3 steps I do 30 ft lbs then 50 ft lbs and the final 85 ft lbs
If you use the fel-pro perma torque gasket ( I highly recommend them) you do not need to retorque the head .
I hope that helps !
California Codfish
Sep 19, 2023 04:08 PM
breezesboy
May 4, 2015 05:37 PM
wulleebullee
May 17, 2011 08:51 AM
kenpobuck
29
Jan 26, 2010 11:34 AM
rsdjcarter
Jul 15, 2009 07:20 PM
