New ford AIS intake
Old Apr 5, 2012 | 05:46 PM
Crewcab Turbo's Avatar
Crewcab Turbo
New ford AIS intake
I got a n AIS intake today at my local Ford dealer. Took of my 6637 and installed the setup. Wow! I thought I left my 38r at home. I can't believe how much quieter it is. I'm gona miss the noise of the 38r cus I kinda liked it in a way. My 10 year old daughter got in the truck and 2 minutes down the road she says, daddy your truck is so quiet what did you do? You know it's noticeable when a 10 year old notices without having any knowledge of me doing anything to my truck!
Old Apr 5, 2012 | 06:09 PM
Blown284's Avatar
Blown284
Do you like it better than the 6637?
Old Apr 5, 2012 | 06:33 PM
Crewcab Turbo
So far I like it better than the 6637. I have not driven it long enough to turn my tuner on yet, so I don't know yet how it flows at wot in 80E. I have a 38R and with the 6637 it's pritty loud. Stock turbo it was fine. After a while the 38R can get annoying with the 6637. It came with a new battery tray, a battery wrap, a restriction gage, an air intake temp sensor, air box, air tube, air filter, and hardware. For under $200 the AIS kit seems well worth it. Will see how it flows, there is still the fender sleeve if it pulls in my filter minder.
Old Apr 5, 2012 | 06:47 PM
Tugly's Avatar
Tugly
Ford AIS and 4" exhaust - this is how it breaths. Click on it and go full res to read the gauges if your bandwidth can handle it. 720p does well too.
80e Tune 4in Exhaust.MP4 - YouTube
Old Apr 5, 2012 | 06:48 PM
trekbasso's Avatar
trekbasso
I'll be curious to know how well you like it. I changed mine a few weeks ago, and don't miss the hissing a bit. Runs really good in 80e (DP), but I don't push it real hard very often. And stock turbo, except for upcoming WW.
Old Apr 5, 2012 | 07:45 PM
Crewcab Turbo
Is that your truck? Does it have the fender sleeve? I just did a quick run and got up to 23 lbs boost in 80e and it pulled the filter minder half way in. I may need the fender sleeve? I am verry happy with the filter setup, and the silence.
Old Apr 5, 2012 | 08:45 PM
guitarpicr's Avatar
guitarpicr
Does the AIS setup require any of the original filter box ? I looked on Clay's site & the picture shows a rectangular tube.
Old Apr 5, 2012 | 08:48 PM
Crewcab Turbo
Everything is included. Box and tube
Old Apr 6, 2012 | 12:19 AM
Bonanza35's Avatar
Bonanza35
People had said that the filter minder is weak on the AIS filter. If you switch to the old minder it dosen't pull in as hard. Thats what I have read here.
Chet
Old Apr 6, 2012 | 02:47 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yet another reason I want an AIS. Quality set ups .
Old Apr 6, 2012 | 03:12 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I made my own sleeve. Got a wet vac foam sleeve at hardware store (biggest they had), and I cut an oval hole in the end of the AIS with my dremel. Stuck the foam sleeve in between the two and it works/looks good. Only costs $6 for the foam sleeve. Could wrap that foam sleeve in a paper filter for the wet vac as well and tape it in place, but mine has stayed put just fine.
Old Apr 6, 2012 | 07:16 AM
Tugly's Avatar
Tugly
I had the same problem as Crewcab Turbo, and I did exactly the same thing as Nicmike. I still have a problem if I push too hard in heavy fog/freezing fog (temporarily clogs the filter), but this is not the time to get on it anyway. I disconnected the red line, but this is one of those "at your own risk" things.
Old Apr 6, 2012 | 07:38 AM
Crewcab Turbo
I saw an early 99 a few weeks ago and I am not sure it is the same butt I believe the fender sleeve is a factory ford part on the early 99? The early 99 I saw had no tube going to the front grill area, it only took air from the fender via a simalar sleeve. Anyone have a early 99 that has that setup? Could the fender sleeve be just a factory Ford E99 part?
Old Apr 6, 2012 | 07:53 AM
Izzy351's Avatar
Izzy351
I would think with the 38r, the AIS isn't enough. I'm running close to 40psi with my setup (the 38r is capable of 40psi as well) and the 6637 flows nicely. The AIS been proven to filter extremely well, and is obviously very quiet. But by the same token, there have been several on here that built sheet metal boxes for their 6637 and quiets them down quite a bit as well. If you notice a drop in boost levels after swapping, you can be assured there is more restriction. My $0.02...
Old Apr 6, 2012 | 08:37 AM
trekbasso's Avatar
trekbasso
James at DP recommended to me not to run the AIS because of restriction. But, I took that from their point of view concerning getting maximum perf. For me, with stock injectors and hpop and turbo, not a problem.
I queezed it a little this morning, 23-24 psi boost, no movement with the minder. I don't have the sleeve, but did cut out the side for it just in case.
