Gauge/instrument panel help
Old Apr 6, 2012 | 07:48 PM
82f100460's Avatar
82f100460
Originally Posted by ctubutis
Ammeter/voltmeter, this may take some work, save it for last. The charging system should still work even if the gauge doesn't, I believe there is a shunt on the back of the gauges that provides for that.
I just rewired my ammeter on my 82, I don't think they changed it much so should be the same.
The shunt is located out in the wiring harness by the voltage regulator. The 2 taps are located in 2 different splices in that same general area. One on the main lead coming off the alternator and the other in a splice in the main lead going from the voltage regulator to the power distribution system. They are splices 201 and 202 on the 82 but that is probably not the same on an 89.
As long as your charging system is working, I would definately leave that for last. If your wiring behind the instrument cluster is hacked up then digging around for the correct splices and the shunt won't do any good.
Old Apr 6, 2012 | 07:52 PM
ctubutis's Avatar
ctubutis
Originally Posted by Eddiec1564
In 87 when Ford changed the electronics, they did away with the infamous ICVR. The voltage guage is off the cluster's 12V switched line.
Could well be, I spend most of my time in 80-86 and am going by memory on the 87+ models.
I think it was in 1987 where they also reversed the resistance/gauge reading, IOW low resistance = low reading on the gauge until such point where it went high resistance = low gauge reading.
Look up the senders on an auto parts web site, some of them tell you the resistance ranges.
Old Apr 6, 2012 | 07:54 PM
ctubutis's Avatar
ctubutis
For the gauges, yeah, you're probably right on the shunt's location, I think I was remembering the clusters that only had the red light and not a gauge....
Old Apr 6, 2012 | 10:29 PM
andrew89F250's Avatar
andrew89F250
Awesome info guys thankyou very much. I'll get some pics up of this endeavor ASAP.
Christopher Workman
16
Mar 3, 2018 08:59 AM
BaltoMoJoe
Oct 7, 2014 09:02 PM
79 F100 Stepside
May 7, 2010 04:18 AM
ernesto ruiz
Aug 1, 2004 09:56 PM
construction site
Electrical Systems/Wiring
Feb 1, 2004 11:16 AM
