T-19 Noise
Old Apr 4, 2012 | 04:09 PM
Smokey85's Avatar
Smokey85
T-19 Noise
Hello All,
I own an '85 F-350 with the 6.9 and a T-19. Just a question regarding the T-19 in general. This seems like a beastly transmission and has never failed to operate smoothly for me, but I've noticed that ever since I've had this truck, it has been a groaning and moaning son of a gun.
I've changed the oil in it and replaced with Lucas of the same grade (75w-90), but it's about the same. Oil coming out looking good. It's noisy in all gears, but it shifts perfect and has no slop in it. Truck has about 142,xxx on the clock and was purchased locally by an outfit just north of me. They used it for towing since new. It had a 10K cement hopper behind it most of the time.
I'm just curious if this is just how they are or if the years of towing are getting to it. Never been in another truck with a T-19 (besides my non-running '86), so I don't have another truck to gauge it against. Any help would be great.
Old Apr 4, 2012 | 04:22 PM
lemonshindig's Avatar
lemonshindig
Common sources of noise are bad bearings. Input shaft bearing and pilot bearing. A pilot bearing will likely always make noise. A bad input shaft bearing should stop making noise when you push the clutch in.
But yes, it's pretty common for T-19s. I personally wouldn't worry about it. Just replace both bearings next time you do the clutch kit.
-Matt
Old Apr 5, 2012 | 10:00 AM
Smokey85's Avatar
Smokey85
Thanks for the reply. I was thinking it may have been bearing related. It really howls under engine braking, but does not seem to make any noise at a stop, nor does it make a difference with the clutch engaged or disengaged.
It has a new clutch, but I didn't do the job so I'm not sure what quality of material or workmanship the P.O. put into it. Thanks again.
festus51
Mar 31, 2012 08:52 AM
shane1963
Jun 16, 2011 12:10 AM
1950gmcelc
Oct 12, 2007 12:52 PM
Katfish1989
Feb 16, 2007 07:31 AM
F150Lariat79
Sep 13, 2004 08:40 PM
