Noise in neutral
Old Oct 11, 2007 | 10:52 PM
1950gmcelc's Avatar
1950gmcelc
Unhappy Noise in neutral
Hey guys,
I just bought a 95 F350 powerstroke with a five speed about two monthes ago. So far i have cracked 3 slaves put in a new clutch master, and now have put in a solid mass flywheel conversion. I put the clutch kit in sunday and once you let the clutch out in neutral it makes a loud noise coming from what seems to be the clutch. I realize the kit is supposed to be louder but it just doesn't sound right. If I bring up the rpms a little bit it goes away or if i push the clutch in. Every thing else feels fine great shifts more pedal then the old dmf but now i have this noise.
Any ideas would be great. Thanks
Old Oct 12, 2007 | 01:02 AM
ynevada's Avatar
ynevada
bad throwout bearing? did u replace it?
bad input shaft bearing?
also, i cant remember, but does it have a pilot bearing/bushing? did u replace that, or even put one in?
Old Oct 12, 2007 | 12:39 PM
1950gmcelc's Avatar
1950gmcelc
I replaced the pilot bearing and the throw out bearing and the input shaft felt fine when I had the tranny down. and when you are driving everything feels fine
Old Oct 12, 2007 | 12:52 PM
ynevada's Avatar
ynevada
is the free play adjusted right?
what ur hearing could be the throwout bearing. its still could be bad.
