replacing top ball joint
Old Apr 4, 2012 | 09:04 AM
wizzy214's Avatar
wizzy214
just wondering if its possible to change the top ball joints without special tools.
i know i need to replace them all but the top right one is very loose. when i take off the wheel i can shake the rotor and theres alot of play.
is it pissble with a c clamp and a hammer? to remove and install?
thanks
99 e250 ext
Old Apr 4, 2012 | 09:39 AM
95e150CW's Avatar
95e150CW
With some pipe, or very large sockets, and a c-clamp, it CAN be done. That said, you really should get your hands on a balljoint press. Autozone rents one for a $100 deposit, which is returned when you are done. Make sure you can get your hands on a vice, and I strongly recommend an impact gun to operate the press.
If you use a c-clamp, make sure it is one hell of a clamp. The ball joint press I use is about 35 lbs, and a huge chunk of cast iron. If you spray the ball joints a day or two in advance it will help a LOT. I have 6 E-series on my farm, and several F-series, and have replaced joints on ALL of them in the past month. None of them had bad upper joints, ALL of them had bad lowers. Double check your findings to make sure your bottoms are not shot too. They carry 100% of the vehicles front axle weight. The uppers mostly take side loading forces when steering, etc.
Old Apr 4, 2012 | 10:30 AM
blageurt's Avatar
blageurt
I guess if you have enough time you can do anything ... I recomend either buying the tool or renting / borrowing it ... the 250 and 350 require a special adaptor socket with a cut out to remove the upper...I had to buy it along with the ball joint tool kit , which came with 6 adaptors but not the special "econoline" one ...if I knew how to post pictures, I could show you a picture of what it looks like ...
Old Apr 5, 2012 | 07:14 AM
dennyo's Avatar
dennyo
I've done this enough times to say it would be far easier to get a BJ tool from a parts store(already mentioned).This is not the hardest job but why make it harder?The right tools go a long way in making an unpleasant task bearable.not to mention safer. That being said,are you sure it's the bj and not wheel bearing?As mentioned earlier soak them prior to taking them out.And if you're going to go through all this work you may as well do both.Just my 2cents
Old Apr 5, 2012 | 07:57 AM
95e150CW's Avatar
95e150CW
Since you MUST press the bottom joint out to get the top joint out, might as well, even if they are 'good'.
Old Apr 5, 2012 | 10:36 AM
JWA's Avatar
JWA
Absofrickinglutely on this ^^^!!!
Going this deep into such a project and you're money ahead to change all four. Save yourself the headache of doing this all over again soon after its done!
jeep_guy48
Sep 28, 2014 03:53 PM
afunk
Aug 17, 2006 04:22 PM
gatorpsd
Dec 17, 2005 10:44 PM
screwy
1978 - 1996 Big Bronco
Nov 22, 2003 01:56 PM
ricgen
Apr 2, 2003 08:16 PM
