Oil drain plug
Old 03-21-2012, 08:30 PM
lwclark's Avatar
lwclark
lwclark is offline
Oil drain plug
Hi guys. My oil drain plug won't tighten. It just spins and spins. It had a bunch of plumber's tape on it, obviously a P.O. knew about it. A new oil pan is the only solution that I can think of. Is there a common and cheaper fix?
Old 03-21-2012, 08:42 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
they make kits that fix stripped oil pan threads. you retap the hole and then you install an oversized plug. or you could be really hillbilly and weld a nut on the bottom of the pan over the hole and plug it with a bolt and soft washer. no offense to any hillbillys of course.
Old 03-21-2012, 09:14 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
Hillbillies are people too - aren't they?
Old 03-21-2012, 09:27 PM
F250racer's Avatar
F250racer
F250racer is offline
drill/tap or get one of those expandable rubber plugs
Old 03-22-2012, 12:13 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Happened to me first time I changed the oil in my 223. Town is a 24 mile round trip so I put a 3/4" length of fuel line over a round head bolt, maybe 5/16 or whatever fit, stuck it in the hole, held the threaded end with vice grips and expanded the rubber plug. There was a washer both sides of the rubber. The free version of the one f250racer suggested. Never leaked a drop.You could double nut it or use a nyloc nut if it made you feel safer......
Old 03-24-2012, 05:54 PM
thundersnow70
yea Buzz, hillbillys are people to. my wife says i am one. GB...great pic! i'm gonna have to remember that one.
Old 04-03-2012, 07:06 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
There are two different sized oversized drain plugs sold by parts stores. These plugs cut their own threads, so there is no need to drill and tap.
schmitty99
05-08-2011 09:17 PM
Flaflathead
03-24-2006 06:23 PM
shadetree1
General Automotive Discussion
12-17-2004 09:51 PM
rebelbob
Oil & Lubrication
06-27-2003 07:45 PM
cajunbronco
05-22-2002 05:29 AM
Quick Reply: Oil drain plug
