fuel system
Old Apr 2, 2012 | 07:43 PM
kyleandlisa's Avatar
kyleandlisa
fuel system
i have a leak at the fuel high pressure hose elbow. does that thread in or connect and is there a special tool for this also do you have to take off the turbo manifold. thanks
Old Apr 2, 2012 | 08:21 PM
BigAlsPSD's Avatar
BigAlsPSD
Where are you referring to?
The braided lines? Those are High pressure oil, and yes there is a tool to unlock the quick disconnect.
Ken(Woodnthings) had a great post with some info on the HPOP lines. https://www.ford-trucks.com/forums/1...l#post11336134
Old Apr 2, 2012 | 10:05 PM
kyleandlisa
fuel leak
it is the connection from the high pressure supply into the head do you have to take off the turbo manifold to change this out
Old Apr 2, 2012 | 10:49 PM
BigAlsPSD's Avatar
BigAlsPSD
No you shouldn't have to remove the Y-pipe if we are talking about the High Pressure oil Lines. Here is a write-up from Clay
HPOP_Hose_Replacement.pdf
Old Apr 3, 2012 | 12:01 AM
DieselOrings's Avatar
DieselOrings
SPONSOR
If you are dealing with a fuel leak at the engine fuel rail, it is probably the one at the rear of the passenger's head. This is the fuel rail connection that usually goes first.
There is no special tools required to remove the nut on the fitting but the easiest way to reach it is to remove the air intake assembly from the valley. This the the aluminum air flow director that has the 4 boots attached to it that is commonly called the 'spider' assembly. Once it is removed, it is an easy reach to go under the turbine housing and remove the nut. This is a compression type of connector that uses a special elastomer sleeve that is compressed similar to a copper tubing compression fitting. The elastomer compression sleeve will become hard and cracked with time and heat. The only thing you can do to repair it is to replace it with a new sleeve after cleaning all remnants of the old sleeve from the brass nut. The new sleeves are soft and flexible and will easily slip over the flare on the end of the tubing. Then just re-tighten the brass nut, compressing the sleeve until the brass nut just barely touches the fitting body.
We do have the new sleeves available at our store.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old Apr 3, 2012 | 12:16 AM
kyleandlisa
fuel leak
i think it's the hpop line passenger side. is there fuel in this line or just oil because the puddle under my truck smells like diesel
Old Apr 3, 2012 | 12:20 AM
BigAlsPSD's Avatar
BigAlsPSD
If it's the HPOP line it is oil, there are fuel lines that run down the passenger's side head though as well, but they will be hard lines.
Old Apr 3, 2012 | 12:29 AM
kyleandlisa
fuel leak
it's the fitting right behind the turbo manifold on the passenger side it's a hard line. my ford dealer said it is a fuel high pressure hose elbow. part number 9N332AA. does this require a tool?
Old Apr 3, 2012 | 01:16 AM
big poppa's Avatar
big poppa
That is the line Bob (Diesel o-rings) above mentioned to you. Unless the line itself isn't leaking from the hold down clip area you can reuse that line and install a new sleave from Bob in the back like I did, better service and a heck of alot cheaper than Ford. I did mine for preventetive maintence and I'm glad I did, mine was beat, brittle. While your at it just replace the other side sleave or o-ring, can't remember going to the fuel bowl and be done with that side. Welcome to FTE by the way..
Old Apr 3, 2012 | 08:42 AM
kyleandlisa
Smile fuel leak
thanks guys for all your help. i think i finally have the right answers i need to fix the problem.
Old Apr 3, 2012 | 09:16 AM
timmyboy76's Avatar
timmyboy76
Just replaced mine the other day, as well...used 1 from first pic. Worked great to remove the old-brittled ones.
Pick - Harbor Freight Tools
Old Apr 3, 2012 | 09:30 AM
mueckster's Avatar
mueckster
If the fuel sleeve is stiff and stays inside the nut, hook the sleeve with the pick to hold it in place and "unscrew" the nut off the sleeve. Works alot easier than trying to dig it out.
Old Apr 3, 2012 | 02:46 PM
kyleandlisa
Smile fuel leak
turns out the fuel line was chaffed at the bracket in the middle and split about a half inch. once i got the turbo manifold off i could see things clearly. thanks for the help though, i'm sure i'll be back
Old Apr 3, 2012 | 07:09 PM
BigAlsPSD's Avatar
BigAlsPSD
Glad you found it, it's actually pretty common... Here is a link to the Failure Prevention Thread might help keep things in check!
Old Apr 3, 2012 | 08:07 PM
woodnthings's Avatar
woodnthings
Here is a diagram of the fuel lines to add to this thread. It will hopefully help reduce confusion later on. Item 19 is the line that rubs through.
Here is the clamp that causes the damage.
And the fix by wrapping it with a thick tape (self adhesive tape)
eyyu
Jan 8, 2019 09:11 AM
CrazyCajun
Jul 18, 2014 09:11 PM
dhag911
21
Jun 5, 2014 01:30 AM
Jmatthews
13
Jan 30, 2013 07:50 AM
