Sponsored by: Auxito
300 swap
Old Apr 2, 2012 | 03:10 PM
creedence18's Avatar
creedence18
300 swap
I was wondering if it is possible to swap in a 300 I6 into a '97; assuming that it will bolt-up to the transmission. I'm hoping that someone else has tried it and hasn't run into major clearance issues aside from having to switch to an electric fan and put in a different fan shroud.
Old Apr 3, 2012 | 09:48 AM
Bluegrass 7's Avatar
Bluegrass 7
Big issue is the ECM and all the harness has to come with the motor.
Reasons are the EEC control is Speed Density , not mass air assuming a fuel injection motor.
Nothing is interchangable with the PCM system you now have as well as transmision control with the EEC system won't cut it either unless you go to a stand alone controller.
I would not think all this hassle would be worth it.
Something most forget or don't think about is this sort of conversion makes you the sole expert on what you have since no shop would want to touch it from a responsalibity for work standpoint for fixing or sorting out any issues.
Good luck.
Old Apr 4, 2012 | 12:29 AM
creedence18
I was planning on going with a carbureted motor instead of computerized; I have the manual transmission and transfercase, so I think I can cut computers out of the equation entirely aside from having to figure out what to do with the speed sensor. I know my speed from my tach and GPS anyhow. Thanks for letting me know that no shop would touch it though.
Old Apr 4, 2012 | 06:40 AM
critterf1's Avatar
critterf1
You will have NO gauges that work either.
Old Apr 4, 2012 | 08:16 PM
Bluegrass 7
This is the value of stating the full info and intent the first time to save from chasing things needlessly.
Few here ever want to revert back to the 70s, 80s and early 90s for motors.
The I6 was last offered with fuel injection in the early 90s as a 4.9L MAP controlled motor..
That's why you got that answer.
Good luck.
jacob spainhoward
1983 - 2012 Ranger & B-Series
Mar 21, 2019 10:18 AM
shty150
1947 and Older Ford Trucks
Aug 21, 2017 10:16 PM
g0226
Oct 29, 2006 11:56 AM
mramc1
Jan 14, 2004 07:42 PM
Brian79150
Nov 27, 2003 01:02 PM
