I rewired my truck and its a 63 but the motor is a 78 302 with a c4, Well i finished or thought i was but i have this resistor wire and cant find out where to put it any sugestions. Its a little pink wire. I started it and it makes this winding noise, and when i shut it down or turn the key off it winds down and takes a couple seconds to stop after i turn the key???
Resistor wire leaves run position of ignition switch to + side of coil. Start position provides full battery voltage for starting. Here is a DSII diagram. Not shown is a wire from "I" term of starter solenoid tied in at firewall.
Nice looking ride, mentioned 'rewire', in the event it's an aftermarket kit then the copy of the ignition circuit I posted will likely be useless; unfortunately the pic is pathetic perhaps another member can provide one better. May want to consider purchasing the wiring manual, I found it extremely helpful tracing down the occasional electrical gremlins. Most Ford supplier's carry them, purchased mine directly from Jim Osborn Reproductions for $7.
I rewired my truck and its a 63 but the motor is a 78 302 with a C4. I finished or thought i was but, I have this resistor wire and can't find out where to put it, any suggestions.
