Need Help With Ford Cummins Build
Old Apr 2, 2012 | 02:37 AM
m.a.r's Avatar
m.a.r
Okay so i recently was given a 84 gas f250 auto front wheel drive, which gets 10 miles per gallon and the only thing that works is the axle and frame. I would throw it out but it has sentimental value, and artwork on the body. So I'm planning to do a huge overhaul and basically turn it into a hot rod. the problem is that i don't have a lot of free time right now and the time i do have i'm sleep deprived and not quite functioning properly. So i have assembled all of the parts that i'm putting in and I would like you guys to give it a once over and tell me if i have made mistakes, what kind of estimates you have for horsepower it will develop, 0-60 times, top speed, etc. any information is welcome. What I have now is kinda stressing the budget so if you know where i can get some of this stuff cheaper that would be nice, but i'm open to suggestions for better parts and such.
P.S. I can't decide on a transmission so I would love suggestions any thing under 4k is good.
Part Number 37095, 37038 Monroe Shocks
Remanufactured Cummins 03 5.9 liter 24v HO (Vin) C 305 horsepower
http://fordcummins.com/80-ford-24v-e...nting-kit.html
http://sourceautomotive.biz/2003-200...nturbokit.aspx
http://sourceautomotive.biz/flex-a-l...icfan1994-2002.
http://sourceautomotive.biz/royalpur...itive16oz.aspx
http://www.automotix.net/usedengines...to-engines.com
http://www.pepboys.com/car_care/oil_...tor_oil/00970/
http://www.amazon.com/K-N-PS-4003-Oi.../dp/B0067ED1S6
http://www.xtremediesel.com/meangree...nator1398.aspx
http://www.xtremediesel.com/afepower...d46-40011.aspx
http://www.xtremediesel.com/afehighf...r30-10102.aspx
http://sourceautomotive.biz/afesilen...2003-2007.aspx
http://www.xtremediesel.com/atsdiese...tercooler.aspx
http://www.xtremediesel.com/bankspow...shboardpc.aspx
http://www.xtremediesel.com/borgeson...ade800116.aspx
http://www.pepboys.com/product/detai...er_gasket_kit/
http://www.xrcbrakes.com/shop.aspx?pg=checkout
http://www.xtremediesel.com/thermote...gkit15002.aspx
http://www.ledoutfitters.com/index.p...product_id=115
http://www.xtremediesel.com/mishimot...eradiator.aspx
http://www.xtremediesel.com/mishimot...e-ram-03d.aspx
http://www.xtremediesel.com/bd-power...ownsystem.aspx
http://www.xtremediesel.com/bullydog...uid105100.aspx
http://www.por15.com/POR-15/productinfo/1GB/
http://www.racelogic.co.uk/index.php...ontrol?start=6
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
http://brakeperformance.com/brake-ro....php?did=11305
http://brakeperformance.com/brake-li...rake-Lines.php
http://brakeperformance.com/master-c...-Cylinders.php
http://www.hawkperformance.com/performance/ceramic.php
http://www.xtremediesel.com/fasspowe...onsystems.aspx
http://www.xtremediesel.com/alsliner...sereducer.aspx
Old Apr 2, 2012 | 09:28 PM
deck60's Avatar
deck60
well most of your links don't work
for trannies I prefer manual so you should go with a 4500 or a 5600 if you want a auto get a 47rh it is a manual shift trannie and can be built for what you want
Old Apr 2, 2012 | 09:53 PM
m.a.r's Avatar
m.a.r
Sorry bout that the links should work now
Old Apr 5, 2012 | 06:58 PM
deck60's Avatar
deck60
first question you want a hot rod then why not use the 12v for 2-3 hrs work and just a couple of gaskets less that 10.00 you can have 350-500 hp real easy why go with an engine you have to computer control now you could put a p pump on that 24 valve and have something
willowbilly3
1947 and Older Ford Trucks
Feb 22, 2016 09:02 AM
earthquake68
24
Mar 26, 2014 04:42 PM
460 FORD MAN
Offroad & 4x4
Sep 1, 2013 01:12 PM
Buzz44
May 30, 2012 12:40 AM
helifixer
Sep 12, 2009 11:58 PM
