rear main tool ???
Old Apr 1, 2012 | 09:14 PM
jg96powerstroker's Avatar
jg96powerstroker
rear main tool ???
hey guys doing a new rear main seal as i get her ready to in sthall, do you need a tool for this or how do you guys do it thanks
Old Apr 1, 2012 | 11:12 PM
1973dieselhighboy's Avatar
1973dieselhighboy
i have always used the flexplate spacer or flywheel to install the sleeve cause or tool at the shop got lost, just put a bead of silicone on the back of the rear main along the flange that the bolts go threw and then line it up and i always give the sleeve a couple light taps with a hammer just enough to hold it on the crank and then i use 3 or 4 bolts and slowly tighten them down evenly with the flexplate spacer in place but dont tighten it down all the way the last thread on the bolt will get damaged and will make it hard to get out, just go till they snug down and then remove and thigthen the rear main bolts and then install the flexplate and spacer and tighten all the way, if you are using a flywheel you can just run them down even till they are tight
Memphis_Sean
Nov 15, 2014 10:00 AM
TA455HO
Sep 26, 2014 03:47 PM
Xclimation
Jul 22, 2011 10:54 AM
grudgeracer
Apr 25, 2011 08:29 PM
hster
Aug 18, 2004 09:27 PM
