Running Lights Power Source... HELP
Old Apr 1, 2012 | 08:48 PM
ToMang07's Avatar
ToMang07
Ok, I have my new mirrors installed.... I have the power adjustment hooked up/working, blinkers working, heat working.
I can't for the life of me find the "Dark Brown" wire that is supposed to be the running lights power source.
Anyone? I'd really like to get this project wrapped up so I can drive my damn truck.
Old Apr 1, 2012 | 08:56 PM
BigAlsPSD's Avatar
BigAlsPSD
Where are you looking? There are browns in quite a few places...
Old Apr 1, 2012 | 08:57 PM
ToMang07's Avatar
ToMang07
I have tried 3 so far, the one in the light switch, and 2 on the main harness to the left of the brake petal. (Both had stripes tho.)
Old Apr 1, 2012 | 09:00 PM
F350-6's Avatar
F350-6
I don't remember if it has a stripe or not. I tied into the running light wire behind the headlight switch. Just pull the switch out and tap into it from there.
Worst case, run it back to the trailer plug wiring and find the brown wire there.
Old Apr 1, 2012 | 09:01 PM
ToMang07's Avatar
ToMang07
Any idea which one it is?
Old Apr 1, 2012 | 09:02 PM
BigAlsPSD's Avatar
BigAlsPSD
I did behind the headlamp switch as well, seems like it does have a black stripe. I'll check the diagram.
Firefighter 1406's Avatar
Firefighter 1406
Also went behind the light switch. Tight fit but it might be easier to crimp if you take the dash panel off.
Old Apr 1, 2012 | 09:07 PM
BigAlsPSD's Avatar
BigAlsPSD
Nope, just labelled as brown in the schematics I have.
Old Apr 1, 2012 | 09:54 PM
ToMang07's Avatar
ToMang07
I think the mirrors are f***ed up. I don't know how tho. Both wires were soldered, all the wires were ran together. (Each side.)
Everything works but the mirror running lights. The brown wire in the switch IS putting out 11.8 volts. So I don't think it's a source issue. I just don't understand how BOTH could be not working. FML.
Old Apr 1, 2012 | 10:50 PM
emery72's Avatar
emery72
What mirrors did you get - oem or aftermarket? I want to upgrade to the heated & lighted mirrors.
Old Apr 1, 2012 | 10:52 PM
Firefighter 1406
Go oem. I speak from experience.
Old Apr 1, 2012 | 11:04 PM
ToMang07's Avatar
ToMang07
Aftermarket. KoolVue. Heard nothing but good things about them.
Yeah, well, good for you I guess. I wanted heated mirrors with the blinker/running lights.
Old Apr 2, 2012 | 07:43 AM
acf6's Avatar
acf6
Pics or it didnt happen! How much did you pay for them if you dont mind telling... i would like to buy a set like that also, but no way i can afford OEM mirrors
Old Apr 2, 2012 | 08:55 AM
ToMang07's Avatar
ToMang07
I got them here: Discount Auto Mirrors - kool vue mirrors - Kool Vue Mirror
I want to say after shipping it was $250ish. If I could get the damn running lights working I would say 100% worth it. But the fact that I can't get the damn running lights working really has me T'd off.
Old Apr 2, 2012 | 10:17 AM
acf6's Avatar
acf6
Wow that's pretty good I paid $250 for OEM Ford mirrors with power only
