Fuel gauge problem?
Old Apr 1, 2012 | 07:25 PM
joel79ford's Avatar
joel79ford
Fuel gauge problem?
When i turn on my truck the gauge moves but only stays at E
Could i have a stuck sending unit, or could it be something else?(electric?)
Old Apr 1, 2012 | 07:31 PM
J ballan's Avatar
J ballan
Mine was acting similar and it ended up having corrosion on top of the sender and in the wiring connector. Replaced wiring connector and it started working good.
Old Apr 1, 2012 | 07:36 PM
PRIMERED79 SHORT BED's Avatar
Ground the sending unit, see if it moves then.
Old Apr 1, 2012 | 07:51 PM
mikeo0o0o0's Avatar
mikeo0o0o0
At the sending unit, unplug the wire and ground the one that goes to the gauge. With the ignition "on" the gauge should swing all the way to full. If it does, either the sender is bad or the ground is bad.
One other possibility is the float has a crack and is fuel logged (sunk). The floats are available separatley.
Old Apr 1, 2012 | 08:14 PM
joel79ford's Avatar
joel79ford
what do you mean by "Ground the sending unit"?
Old Apr 1, 2012 | 08:17 PM
joel79ford's Avatar
joel79ford
and would i have to drop the gas tank or remove the bed for this?
Old Apr 1, 2012 | 08:49 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No, you don't ground the sending unit itself.
There are two wires that go to the sending unit. One is a short wire that is a ground. It is screwed to the crossmember in front of the tank. The other wire is the wire that goes to gauge. Unplug the wiring harness at the sending unit. Find a good CLEAN section of the frame. Take the wire that goes to the gauge and ground it to the frame. With the ignition in the "on" position the gauge should swing over to full.
You don't need to drop the tank to do this test, just unplug the wiring harness.
The first picture is the sending unit wiring harness, this gets unplugged from the tank.
The second picture shows the front of the tank with the plug and sending unit.
Old Apr 1, 2012 | 08:59 PM
joel79ford's Avatar
joel79ford
and doing this will determine what the problem?
Old Apr 1, 2012 | 09:01 PM
Where do you get the plastic separators between the tank and strap?
Old Apr 1, 2012 | 09:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
This will tell you whether the problem is the sending unit or there is a gauge/wiring problem.
If you ground the wire and the needle swings over, everything to the point where you grounded it is good. That means either the sending unit is bad or the ground connection at the crossmember is bad and needs to be cleaned. One other possibilty, like I said above, is a cracked float. This is a common problem. The float is brass and can develop cracks or the solder joint on it can also crack allowing the float to fill with fuel and sink to the bottom of the tank, making the tank always read "empty".
If the gauge doesn't swing to full, then the problem is either the gauge itself, the wiring from the gauge to the sender or the power to the gauge.
Old Apr 1, 2012 | 09:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Those are new straps, the insulators came with the straps.
Old Apr 3, 2012 | 10:39 PM
joel79ford's Avatar
joel79ford
hey um, what do you mean by"ground it to the frame"?
do i just hold it down to the frame while someone checks the gauge move?
Old Apr 3, 2012 | 10:49 PM
7636074460's Avatar
7636074460
another option is to unplug the connector and connect it to a jumper wire from a known good ground, that way you can connect it then sit in the seat and see if the gauge swings.
Old Apr 3, 2012 | 10:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes. The socket in the wiring harness is a female so you'll need to stick a nail, small screw driver, screw or something similar in the socket's terminal, then, find a clean area (or clean an area) on the frame and touch the screw or whatever you used to the clean area and have someone turn on the ignition and watch to see what the gauge needle does.
Old Apr 3, 2012 | 11:26 PM
joel79ford's Avatar
joel79ford
oh ok, thank you very much
i will get back to you guys tomorow
