Fuel gauge problem?
Old Apr 4, 2012 | 08:48 AM
Blown 331's Avatar
Blown 331
Originally Posted by mikeo0o0o0
One other possibility is the float has a crack and is fuel logged (sunk). The floats are available separatley.
I had this problem on my highboy. Its really easy to change when the fuel tank is behind the seat!
Old Apr 4, 2012 | 10:29 AM
joel79ford's Avatar
joel79ford
Hey guys I know this is sorta off topic, but where is the engine temp sending unit located at?
I'm having suspension that It may not be working correctly
Old Apr 4, 2012 | 11:00 AM
Blown 331's Avatar
Blown 331
351m/400? Passenger side, somewhat high up on the front of the block.
Old Apr 4, 2012 | 11:24 AM
joel79ford's Avatar
joel79ford
Alright guys I just did the test
I grounded the wireing harness and the needle did go all the way to full
so What's next?
Old Apr 4, 2012 | 11:40 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Okay, everything from the gauge to the point you grounded is okay. The problem is after that point.
Before you hook the wiring back up look at the gauge, turn the key to on. Does it move any at all? If not, hook the wiring back up and do it again. Watch the needle and see if it moves at all. If it moves a small amount you may have a sunken float. These can be replaced separate from the sending unit.
If it doesn't appear to move the next step is to check the ground connection from the sending unit. On the sending unit you'll see one short black wire that is attached to the crossmember in front of the sending unit by a screw. Take this screw out and clean both the terminal and the attaching point on the crossmember. Now would be a good time to make sure the terminals and connectors at the sending unit are clean too. Reattach the ground wire and make sure to plug the sending unit back in. Turn the key on and watch the gauge. If it still reads empty the sending unit is more than likely the culprit.
Old Apr 4, 2012 | 05:45 PM
joel79ford's Avatar
joel79ford
yeah...after i cleaned both the ground and wiring its still doing the same thing...it moves but stops immideatly at E
so i guess my float is sunken..
its funny though b/c after i tested the ground on the wiring harness, i quickly connected it back to the tank and i watched the needle go down and stop at about a quarter of tank(thats how much i have in the tank right now)
anyways, do i have to drop the tank to replace the float?
Old Apr 4, 2012 | 05:47 PM
joel79ford's Avatar
joel79ford
wait the float is the sending unit or their completely different?
Old Apr 4, 2012 | 08:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here is a picture of the sending unit. The float is to the left side of the unit. You can see that it just "clips" to the float arm.
I think you can pull the sender out without dropping the tank but not 100% sure. The bed was off mine.
Old Apr 4, 2012 | 08:38 PM
joel79ford's Avatar
joel79ford
so Its that gray thing that's attached to the unit?
Old Apr 4, 2012 | 09:21 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No, the "gray thing" is the rheostat. The float is the round cylindrical object at the left end of the assembly. It has the silver gray "hook" around it.
The other round "thing" with the tube going in the right side of it is the strainer, aka "sock". This is the first fuel filter. It's a coarse nylon mesh that will filter out the big stuff before it gets to the pump.
Old Apr 4, 2012 | 09:26 PM
joel79ford's Avatar
joel79ford
Oh OK, I guess I will have to go to the junk yard tomorrow And look for one
Should I might as well get the whole new sending unit?
Old Apr 4, 2012 | 09:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I would pull the old one first to see if it is a bad unit and not just a sunk float. If the sender itself is bad I would go with new rather than used.
Old Apr 4, 2012 | 10:28 PM
  #28
joel79ford's Avatar
joel79ford
Ok I will check to see if the floater is still there
and if it is then that means the whole sending unit.is bad right?
Old Apr 5, 2012 | 08:52 AM
  #29
mikeo0o0o0's Avatar
mikeo0o0o0
Don't jump the gun. Once the sending unit is out of the tank take the float off, it will just unclip. Shake it and see if you can hear or feel any fuel sloshing around, you shouldn't. Also, the float should feel light, not heavy.
One thing you might try. Once the sender is out, plug the harness back in and turn the key on. Hae someone watch the gauge. Move the float arm up and down and see what the gauge does. If it moves, the float is bad if the needle doesn't move, replace the whole sending unit.
Old May 7, 2012 | 06:54 PM
  #30
joel79ford's Avatar
joel79ford
Hey guys, its been a while since i tried, well i havnt really tried droping the tank to fix the problem, anyways
Last week when i got home from school, before i turned my truck, i looked at the gas gauge and noticed it was marking half tank!
The day before that i filled the truck with about 40 bucks(9 gallons) which is very close to a half tank
so i turned off my truck, immediately turned it back on and it was still marking half tank
The next day i turned it on in the morning so i cant let it warm up before school, but once again the needle moved to only right on the E
When i took off, i hoped it would move, but nothing
After school i turned my engine and didnt pay attention to my dash
Half way home i look at the gauge and saw it was reading Half tank
The only thing iv been doing on my truck is using 1st more often
i really dont use it since its the granny gear
Am i not getting enough power to my gauge or something??
or is my truck Mocking me???
