Need HELP!
Old Apr 1, 2012 | 07:03 PM
redding's Avatar
redding
Need HELP!
I have a '05 6 cylinder that has 98k miles and has been sitting for 6 months. Replaced battery, checked all fluids, filled it up with high test and gas treatment and it ran fine for 100 miles or so and all of a sudden, no power, no acceleration, backfiring, etc., but runs pretty good at idle. I am not a mechanic but have DIY capabilities...where should I start? Please help, I have to get this truck up and running and just don't have the money for a mechanic/dealer right now. Thanks in advance for all replies.
Old Apr 2, 2012 | 08:03 AM
redding's Avatar
redding
Thanks for all the help...you guys are great!
Old Apr 2, 2012 | 09:07 AM
greenego's Avatar
greenego
Change the fuel filter and check fuel pressure to make sure pump isn't failing.
Old Apr 2, 2012 | 10:04 AM
Coskid's Avatar
Coskid
Buddy you have to give people more then 12 hours to get on as we are not usually on much during Sunday nights.
Anyway the fuel filter would be a good place to start as it is most likely clogged now after the initial miles you ran.
Old Apr 2, 2012 | 03:12 PM
Stewart_H's Avatar
Stewart_H
Redding, sometimes responses take a little bit of time. Please be patient.
Here's another bump to the top for ya.
Stewart
Old Apr 2, 2012 | 10:44 PM
Papa Tiger's Avatar
Papa Tiger
Add your choice of fuel additives to help it after changing the filter and fuel pump PSI tests. Double check all our vacuum hoses for off/damaged/split ends. Including the PCV system. Check to make sure your intake manifold is good to go, it may be leaking.
yellowone
Mar 25, 2017 07:48 PM
Tulsa
Sep 4, 2011 02:27 PM
gbrett
Dec 24, 2009 04:11 PM
J-dizzle
Mar 3, 2006 10:08 PM
fatswany
Jan 4, 2005 07:48 PM
