I'm stumped
Old Apr 4, 2012 | 08:30 AM
zhilton's Avatar
zhilton
Are your injectors Ford Remans or some other brand? It's possible you have one not quite up to snuff. A ScanGauge may show a contribution/balance code. And like Benny suggested, an AE will for sure pick it off either through a KOER test or Power Balance test if it is in deed a week injector.
The Yukon is a little far for me to drive with my AE...though I wouldn't mind visiting the area some day.
Originally Posted by Yukon Beast
i have allready done all the injectors and hopfully i'll put the blue spring at the end of the week. keep fingers crossed they have one in stock.
Not sure where you getting your blue spring, but if your local source doesn't have it...check with Clay at RiffRaff
Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit - OUT OF STOCK
(Yes, I realize it says he's out of stock...but I'm willing to bet it won't take him long to get it back in stock)
Old Apr 4, 2012 | 05:00 PM
Yukon Beast's Avatar
Yukon Beast
blue spring kit ordered and on its way
it may be a long way to the Yukon but it is worth the trip trust me
Old Apr 4, 2012 | 05:10 PM
Yukon Beast
Originally Posted by lenzhotrod
You say "after it warms up", what is your actual "temperature" ? Do you know your fuel pressure? Has the turbo been cleaned, and can you command it open and closed and hear a difference? Has an injector buzz test been performed? How about a cylinder balance test? What are yor FICM voltages when cold, cranking,warm? All guesses from this side. Test,verify,repair.
i dont have any gauges yet so i cant tell you what the temp is,but i can say that i have been driving at hwy speeds for at least 25 miles after a 15-20 min warm up. the turbo not sure what you mean "command it open and closed" i can hear it change when the truck is warming up. im going to talk to my buddy with his scanner and see if he can do those tests. the ficm has just been repaired by ed and was reading 47 volts running.
Old Apr 4, 2012 | 05:49 PM
yukonsam's Avatar
yukonsam
I can always grab one and stick it on Air North for you if you need one sooner haha. Hopefully the blue spring fixes it! I want to get one in mine soon!
Old Apr 4, 2012 | 06:10 PM
Yukon Beast
it is in-route as we speak but thanks for the offer
Old Apr 6, 2012 | 12:48 AM
Yukon Beast
i hate it when you pay for over night delivery and it takes days to receive it. now going to have to wait until Tuesday, after the long weekend.
Old Apr 7, 2012 | 04:58 AM
Yukon Beast
im thinking that this might be coming from the torque converter, the last two days when this shudder happens i just let it shudder. (most of the time i would step on the throttle and it will stop) i noticed that the motor does not sound like it is missing, it has a steady rev to it.
Old Apr 7, 2012 | 05:16 PM
Roasted7's Avatar
Roasted7
not in the drivetrain it is all good but thanks
Yep.
Old Apr 7, 2012 | 07:24 PM
BLADE35's Avatar
BLADE35
A bad Tourq converter will shudder diffrent than anything else
Does it drag engine RPM down at stop with vehicle in gear???
Old Apr 7, 2012 | 07:56 PM
Roasted7's Avatar
Roasted7
My truck used to shudder, but at lower speeds than yours. It was the rubber boot around the carrier bearing. It was worn out allowing the drive shaft to flop around in the bracket.
Old Apr 7, 2012 | 09:24 PM
Yukon Beast
nope every thing runs fine only at around 55mph on the first drive of the day.
Old Apr 7, 2012 | 09:29 PM
Yukon Beast
no steady bearing is in great shape and all u joints on dive-shaft and axles are great shape
Old Apr 13, 2012 | 09:28 PM
  #28
Yukon Beast
scan gauge is here. so lets hope i can get this fixed!!!
thaemcee2
May 10, 2017 07:08 PM
Cranemech
Oct 12, 2015 06:15 PM
texnj
Mar 9, 2015 05:46 AM
pile_53574
Nov 15, 2013 06:38 PM
mtpolarbear
Mar 17, 2012 12:09 AM
