Sponsored by: Real Truck
Trailer Weight
Old Apr 29, 2003 | 03:55 PM
BlueJay40's Avatar
BlueJay40
Question Trailer Weight
What is the 5th. wheel trailer weight I can pull with a F350 DW Crew 6.0 long box? I plan on ordering an 04 as soon as Ford will let me.
Old Apr 29, 2003 | 05:36 PM
sportscar's Avatar
sportscar
Trailer Weight
You can find this info on the Ford Truck MFG web site. You can pick up a Ford Towing Guide at the dealership. Tow ratings will also depend on your selection of motor, rear-end ratio, and 2WD vs 4WD.
Old Apr 29, 2003 | 09:29 PM
nafzimo's Avatar
nafzimo
Trailer Weight
Welcome to the site. This recent post may help you.
https://www.ford-trucks.com/forums/s...hreadid=114834
Matt
Old Apr 30, 2003 | 07:36 PM
BlueJay40's Avatar
BlueJay40
Trailer Weight
Can't find anything about towing weights on the ford web site. Need help
Old Apr 30, 2003 | 08:11 PM
Monsta's Avatar
Monsta
Sit. Stay.
Trailer Weight
The FAQ lists them. I would imagine that the 6.0L specs are a tad higher than the 7.3L since it is a bit lighter. You'll definantly be in the infield of the ballpark with the figures listed.
Old Apr 30, 2003 | 09:17 PM
sportscar's Avatar
sportscar
Trailer Weight
try this link:
http://www.fleet.ford.com/products/r...03_default.asp
Its on the Commercial Ford Truck link from the mian Ford page.
Hope this helps
You will need open a .pdf file to read it.
This is the 2003 specs but it should be a help.
Old Apr 30, 2003 | 10:05 PM
fd1506's Avatar
fd1506
Trailer Weight
With the 03 you will be right around 13,500 fifth wheel weight.
That's just app. to get you started. The trailer dealer should have this info as wheel. Hope this helps some.
Old Apr 30, 2003 | 11:46 PM
SouthernDually's Avatar
SouthernDually
Thumbs up Trailer Weight
Another place you can check is www.trailerlife.com. They have a listing for all vehicles or all makes...yes even Chebbys. Just remember that you are looking at the max weight. You need to drop about 600 lbs for your add's. like water. clothes etc. and If you wife packs like mine you might want to drop about 1000lbs. She really likes to pack it in. What kind of trailer are you planning on getting or have?.
tmurray9999
Sep 16, 2012 11:13 PM
CLutchf250
Mar 15, 2010 05:26 PM
hrkdrivr
All Things Towing
37
Apr 7, 2007 11:08 PM
pcingo
Jun 11, 2004 08:10 AM
juhasz
Mar 31, 2003 08:51 AM
