3G wire Help
Old Apr 1, 2012 | 12:20 AM
drizzie27's Avatar
drizzie27
3G wire Help
Alright I got my Alt installed got is tested prior and 100% good. I got it wired all up according to the diagram in a couple post tossed the old harness and meter. I have Zero power. I checked my wires with a volt meter and got 12.4 v on my solenoid but nothing when I try to turn it over. I did have to ground my alt where the bottom bolt holds the alt in place, cause the small bolt I used behind the alt stuck out too far and wouldn't fit. Could my issue be with the ground how I did it? It's a 71 F-250 360cid.
followed this diagram
http://www.fordification.com/galleri.../3Ginstall.jpg
Old Apr 1, 2012 | 09:48 AM
HIO Silver's Avatar
HIO Silver
I don't think it is a grounding issue. The 3G is physically grounded through the casing, bracket, the water pump, to the block.
You may have popped a fusible link or ya mis-wired the thick Black/yellow wire. I'd pull the alternator harness and Ohm it out to verify continuity.
The harness should look and function as pictured below (ignore the text for the ammeters):
Old Apr 1, 2012 | 11:30 AM
drizzie27's Avatar
drizzie27
dude i cant even read the text on this
Old Apr 1, 2012 | 11:34 AM
drizzie27's Avatar
drizzie27
Also where the yellow and black/yellow wire comes into one, mine has two wires that come out one black/ yellow and one black
Old Apr 1, 2012 | 11:44 AM
HIO Silver's Avatar
HIO Silver
Dude, you're the first....Click on the image and it will enlarge to 640 x480 - readable.
You mean where it connects to the solenoid? Peel back the wrap and it'll likely be the Blk/yel and Yellow wires or it has an inline fusible link. Sometimes the colorant wears off. Regardless, it needs to be connected to the battery side terminal.
The Y/wh from the 3G also connects to the hot side or looped to the alternator's battery lug. The Gr/r wires need to be connected to each other.
Old Apr 1, 2012 | 12:18 PM
drizzie27's Avatar
drizzie27
its the color man, bright as hell and jagged
Old Apr 1, 2012 | 12:21 PM
HIO Silver's Avatar
HIO Silver
Increase your screen's resolution. 'You using a "mobile device"?
Old Apr 1, 2012 | 12:32 PM
drizzie27's Avatar
drizzie27
on my PC and Phone its the same, it doesnt help when your color blind either. and no not black and white color blind lol
Old Apr 1, 2012 | 02:39 PM
drizzie27's Avatar
drizzie27
Well I got it working, putting out 14.5 at idle. An a slight squeal on start up and it squeals when I rev it high really fast
Old Apr 1, 2012 | 05:11 PM
HIO Silver's Avatar
HIO Silver
So what was the problem?
Old Apr 1, 2012 | 06:42 PM
drizzie27's Avatar
drizzie27
i think my mistake was putting the black/yellow wire on the starter side of the solenoid. I took the bolts and washers off the starter and used a wire brush to clean up the connection too.
Old Apr 1, 2012 | 08:31 PM
70-360fe's Avatar
70-360fe
I finally got mine going no noise but others have because of using a single v pulley. If you go to a double v you should get rid of the squeal. Double v puleys are available at auto parts stores, online and the junkyard.
Old Apr 2, 2012 | 12:14 PM
rustywheel68's Avatar
rustywheel68
correct- the solenoid is an open switch except when you're cranking the engine over, so the black/yellow wire would not have been getting battery voltage.
Old Apr 2, 2012 | 08:10 PM
f100today's Avatar
f100today
The sequel is from the belt being too loose. Tighten it and it will stop squealing. Doesn't matter if it is a single or double pulley.
Old Apr 3, 2012 | 01:13 PM
drizzie27's Avatar
drizzie27
well i tightened it some more to day and it still squeals.
sere0501
Apr 21, 2018 05:17 PM
Reggie Lewis
Jun 19, 2016 03:15 PM
GM4WALLS
Jul 7, 2015 10:49 PM
alpha/omega
Offroad & 4x4
Jun 6, 2011 08:35 AM
projectbad78
Jul 3, 2008 02:48 AM
