It is hard to imagine something invisible, but if you pay attention you might notice some indicators. On digitally controlled engine you might not notice rpm drop when you turn headlights on, but you might notice difference in engine tone.
On my conversion I do have 7500W alternator, that coupled with inverter I am using for running 1500W roof AC. When I turn the AC on idle, the engine slows down and it takes a lot to slow down Detroit 8V71.
One more tough. The 7500W alternator is run by 2 V-belts. The side fan on diesel pusher is run by 3 V-belts of the same size. And you can spin the fan by hand...
The light gets brighter....but if I turn the light off, I am still cranking the same.
No you are not, but with hand generators low effficiency the bearings and cranks resistance is way bigger then electromagnetic resistance, so you are just not able to notice the difference.
Get a bigger hand generator that you crank at constant speed and have somebody behind you back switching the light on and off?
It is a video of me testing a weed eater motor powered alternator. Motor is running turning alternator, I put a load on the alternator and the motor dies down (loses about 3000RPM). I later did the same test but with headlights hooked up to the battery. Each headlight I turned on drug the motor down about another 1000-2000RPM until I had 2 100W bulbs and 2 55W bulbs lit, turning on 1 more 55W bulb would kill the weed eater motor because of the load the alternator put on it.
Apples and oranges. The hand crank flash light has a generator, not an alternator. They are not the same. A generator DOES put out more energy when spun faster.
For my clarification, the weed eater motor was gasoline??
"electromagnetic resistance", Post #20, is not recognized by Wikipedia. I did find this;
Pappy, you're missing a very critical aspect of the alternator.
An alternator is a set of spinning electromagnets (the field coils), inside a housing of electrical coils called the stator.
Suppose the alternator is spinning at 3000 RPM. No power is being applied to the field coils by the voltage regulator. No power is being generated by the alternator.
Now take the same alternator spinning at 3000 RPM and the voltage regulator applies voltage to the field coils. A spinning electrical field is created that cuts the stator coils of the alternator and electricity is generated.
In short, the alternator is NOT always generating electricity based on it's RPM. It's generating electricity based on the amount of power the voltage regulator applies to the field coils. If the VR says no power is needed, no power is generated and no drag occurs on the alternator. When the VR decides power is needed (battery voltage is low), it applied power to the field coils, electricity is generated and drag on the alternator is increased proportionally.
This may be apples and oranges, but when I show up to an aircraft half awake and gulping coffee, I start the Aux Power Unit, which is just a jet engine with a big generator attached. Once it's up and running, I turn on every exterior light on the airplane so I can go outside and make sure they all work. When I turn everything on, not only do I notice a change in the tone of the APU, but I can also observe an increase in the fuel flow. I could drive my SD 600 miles on the same amount of fuel the APU uses in 20 minutes just to turn the lights on. If the lights are off with just the APU running and no bleed valves open, the same amount of fuel would last about 30 minutes.
Than you can compare generator ratings.
The good ones will list fuel consumption under 1/2 load and under full load. Especially on inverter generators the difference can be close to 70%
One question I have about these new headlights; how many hours will the work before burning out compared to the factory bulbs. If I'm not mistaken the life expectancy of these new bulbs is much less than factory bulbs, therefore they will need to be replaced more often which will end up costing much more than the factory bulbs.
