1986 duraspark conversion 300 I6
Old Apr 2, 2012 | 10:38 AM
vboxingguy's Avatar
vboxingguy
I think the oil pressure has 2 wires going to it. Dont i need both? And i assume the power to the coil comes from the thicker red wire on the truck harness?
Old Apr 2, 2012 | 10:59 AM
JimsRebel's Avatar
JimsRebel
I have only seen a single wire on the oil pressure.
Yes, the fat wire wire in the 4 wire plug is the power feed for the coil.
Jim
Old Apr 2, 2012 | 11:24 AM
vboxingguy's Avatar
vboxingguy
Ok, thanks. Now i got a red w/white stripe, white/red stripe, and red w/yellow stripe on the same plug that i have to figure out what goes where.
Old Apr 2, 2012 | 11:55 AM
JimsRebel's Avatar
JimsRebel
That plug might not be used on your truck.
Do you know what the harness was removed from?
Jim
Old Apr 2, 2012 | 12:42 PM
vboxingguy's Avatar
vboxingguy
That is the plug thats on the truck. The plug has 4 wires on it. A thick red one, red w/wht. White w/red, and red w/ yellow. Not sure what year the harness is off of. I started collecting these parts a while back, but it was a v8 with the blue grommet module.
Old Apr 2, 2012 | 02:06 PM
JimsRebel's Avatar
JimsRebel
Here are some photos of the 4 wire plug. You should have cut the wires on the other side of the plug at the junkyard. The red w /yellow is unused and is shown coiled and tied with a small black tie wrap.
The fat wire downstream of the black (3 in 1 out) splice is the source for the coil positive. The other two wires are for water/oil senders.
Jim
Old Apr 2, 2012 | 02:38 PM
vboxingguy's Avatar
vboxingguy
Somebody else had gotten to the harness before me and cut the plug off. Im going to try and use the plug that is on the truck and wire the new harness to that plug. Thanks again for the help. But i still have to find out if the white w/ red is for the oil or water and vise versa for the red w/ white.
Old Apr 2, 2012 | 02:49 PM
JimsRebel's Avatar
JimsRebel
Just follow the current wire (water/oil) back to the plug.
Old Apr 2, 2012 | 02:55 PM
vboxingguy's Avatar
vboxingguy
Yeah, i guess ill do it that way. I just thought i would ask so i had the new harness allready to go before i took the other one apart. I cant have it sitting for too long. Lol. Thanks again for the help. I think im confident enough to tackle it now. I will let everybody know what i find out and how it works.
Old Apr 2, 2012 | 11:58 PM
vboxingguy's Avatar
vboxingguy
well me and my son pulled it all apart tonight. got all that old junk out of there. i still have to cut open the old harness and trace some wires but hopefully it will be back together tomorrow night.
Old Apr 4, 2012 | 10:11 PM
vboxingguy's Avatar
vboxingguy
Jim
well the conversion went pretty smooth. you were right, i followed the red with yellow and didnt need that one. and i just kept the oil and water temp, from the harness that was on there. and i knew which one was for the coil, so not too bad. i still have a few issues. not sure if they are related ,but they werent there before.
Lucille1986
22
Oct 9, 2015 08:50 PM
Dutch7219
Mar 19, 2015 06:46 AM
cmc2014
Apr 2, 2014 12:39 PM
andy96xlt
Dec 11, 2010 09:02 AM
lightnin
Jan 16, 2002 11:28 PM
