engine swap......
Old Jan 13, 2002 | 09:55 PM
lightnin's Avatar
lightnin
engine swap......
:- fire
hey all...got a 86 f150. just started a swap from
a 300 six to a 351w.got a prob.the 300 is computer
comtroled.ive got a eariler 351 with older ignition.
my wiring has the 9 pin module. the 351 takes a brain box
how do i get the older dist. and brain box wired to work?
please be specific as far as wire routings......thanks.....
Old Jan 13, 2002 | 10:30 PM
Franklin2's Avatar
Franklin2
engine swap......
A wiring diagram for your truck should get you going.
Old Jan 14, 2002 | 11:32 AM
rc351w's Avatar
rc351w
engine swap......
This is a project I did two years ago so I'll save you a lot of time studying and chasing wiring diagrams.
If you have the donor truck/car the motor came out of things are much simpler. You need the coil ,coil/distributer harness and the Daraspark II module from the donor.
Step 1.
There will be a plug on your origonal harness (at the firewall between the master cylinder and inner fender) that has 3 wires (2-white and a red) that mates to one of your Daraspark II plugs (2 wires, red and white).
Step 2.
There will be a plug on your origional harness that has a large (8 gauge?) red wire with a green stripe. Connect this to the same colored wire in the coil/distributer harness.
Step 3.
The 4 wire plug on the Daraspark II module goes to the matching plug on the coil/dist harness.
If you don't have the coil/distributer harness the here's a break down of where each wire goes:
Step 1 is the same.
The red/green wire in step 2 goes to the live side of the coil.
The 4 wires in the second Daraspark II plug:
green goes to the ground on the coil
the other 3 go to the matching colors on the distributer.
Hope this saves you the aggravation I had.
RCC
Old Jan 16, 2002 | 09:48 PM
lightnin's Avatar
lightnin
engine swap......
thanks guys....ive got a wiring digaram now .
with your help ill find out this weekend.
i race a pontiac but i gotta get it to the track.
thanks.....
Old Jan 16, 2002 | 11:28 PM
390GT's Avatar
390GT
engine swap......
