Blown speakers
Old Apr 2, 2012 | 04:33 PM
Fire Rooster's Avatar
Fire Rooster
Originally Posted by Pool Runner
I'm running stock radio, no amp with my Alpines. To be honest you can turn them up as high as the oem radio can go and there is no distortion. I know people say tuners and exhaust systems are some of the best mods for these trucks. IMO the best thing I did for my truck was replace the terrible oem speakers. Good luck
I agree!!!
Old Apr 2, 2012 | 06:59 PM
mrdesanctis's Avatar
mrdesanctis
I haven't had a problem with my truck but I like my music loud and might upgrade just for better sound quality.
Old Apr 2, 2012 | 07:03 PM
mrdesanctis
Originally Posted by D8chumley
Factory speakers are crap. Several people have had the same issue, I replaced mine with 4 of these Rockford Fosgate Prime R1682 6"x8" 2-way car speakers at Crutchfield.com
For ~ $140 I got great speakers that sound awesome and will last. It says they are not for the rear but I talked to a tech there and all I had to do was shim them out away from the inner panel. I just cut the screen out of the old speaker and shimmed them out about 1/8" or so. Careful with the bolt behind the rear ( if SCrew) door handle, both sides had the clip you thread that bolt back into fell into the bottom of the door. They are still there... The door closes fine w/o them in there and appears there are no issues w/o them.
Also be careful with the adapter wires, I bent a prong over rendering it useless in the connector so I had to order another set. They are small and fragile so use caution when connecting them.
do the RF add some bass to the music? I was used to my car that had 2 -12" MTX subs in the trunk when I got my truck and kind of miss the bass. I know it won't be as much as subs but I was wondering if it helped much if any.
Old Apr 2, 2012 | 07:09 PM
mrdesanctis
I will say exhaust is amazing on my 2011 5.0!
Old Apr 3, 2012 | 07:31 AM
Southpaw666's Avatar
Southpaw666
Originally Posted by Fire Rooster
Anyone else having issues with the stock speakers? Took my truck in the morning after I bought it for the passenger side rear speaker cracking. Yesterday I noticed the passengerside front speaker is cracking. I don't turn my stereo up loud and I can't believe they are this bad????
My driver side rear speaker went to a crackle... I told the dealership and he ordered a replacement right away and swapped it in on the oil change the following week.
Old Apr 3, 2012 | 07:58 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Yes i think it added some, but not like subs ike you said. Definately better than OEM's
Old Apr 3, 2012 | 06:02 PM
mrdesanctis
Ok thanks. thats all I needed to hear. time to order.
Old Apr 3, 2012 | 06:10 PM
Pool Runner's Avatar
Pool Runner
Let us know how the RF speakers turn out after you get this done. My Alpines did not improve the bass any, but the highs are super crisp and I can now crank the stereo up as loud as it can go and still not have any distortion. I think the oem speakers were a measly 20w or something pathetic like that. My Alpines are 230w peak & 75w RMS (I'm not a stereo enthusiast) do I don't know what that entirely means but I do know it was a huge improvement over stock.
Old Apr 3, 2012 | 06:20 PM
Fire Rooster
I can't really give an honest reply to that. I already have two RF, tens and a 300w amp pushing them
In my Scab. But volume certainly doesn't need to be up at all with subs added.
Old Apr 5, 2012 | 06:17 PM
soundwave's Avatar
soundwave
Has anyone had an issue with any door panels vibrating from the stock speakers? I have that problem on the drivers side so I took my truck in and they said the speaker was blown. Which was odd because Ive had blown speakers before and Im pretty sure it wasnt the speaker and it was a loose door panel and I told them that. So they replaced the speaker and the problem still is there. I havent had time to go back and sit all day at the dealer.
Old Apr 7, 2012 | 10:16 PM
Fire Rooster
D8 and pool runner, just wanted to say thanks and let you know the install of my RF speakers went well and sounds awesome! Thanks again guys.
catscratch
Nov 13, 2012 07:53 AM
FordPickMeUp
May 20, 2004 07:06 AM
CampingFamily
Apr 30, 2004 03:10 PM
gremlin25
Jan 8, 2004 11:02 PM
Jim242002
1997 - 2003 F150
Mar 10, 2003 08:59 AM
