67' exhast valve trouble.
ive got a 67'f100 with a 72' 302 and it has dual exhaust. Well im pretty sure i have a exhaust valve problem on the driver side. I tried the dollar bill trick and it ripped the bill. So is there any other things to try befor i have to rip the motor apart again? I tried seafoam through the carb and also tried steam cleaning with a turkey baster. Any help would be very very very much apreitiated.
valve problem
After you do the compression test. Remove the valve cover from the bank that has the problem, have someone spin the engine over and watch that all of the rocker arms are moving the same amount. This a long shot but you could have a weak or broken exhaust valve spring or a rocker arm stud that has pulled out . Kenny Nunez
Well its an old time trick were you hold the bill behind the exhaust pipe. If you have a bad valve than it sucks air in. In turn the bill will rip. Its a pretty nifty trick. Do you think that I might just have a weak spring? That way the valve isnt closing because the springs not strong enough?
valve problem
I think it is time to break out the tools and get it over with. Find a good machine shop in your area. Did the engine ever overheat ? Does it have a lot of miles on it ? If so there may be more problems with those heads. Also a good time to replace the timing chain. Good Luck , Kenny Nunez
Eric Kropp
12-03-2014 10:27 PM
lexasgs400
02-20-2012 11:27 AM
SteveInMs
08-12-2009 05:20 PM
sdloe
13
01-05-2004 02:49 PM
