Squeaky Front End
Old Mar 30, 2012 | 08:39 AM
jonny.redneck's Avatar
jonny.redneck
Squeaky Front End
Every time I turn sharp radius, like pulling into a parking spot, my front end squeaks really bad. I took a grease gun to all the steering components and still no improvement. I have also inspected my ball joints and they are in good condition. Anybody have any idea what is wrong?
Old Mar 30, 2012 | 09:46 AM
1986F150six's Avatar
1986F150six
Any possibility that it is the tires making a squealing noise? Some parking lots have a coating over asphalt which is very noisy when wheels are cut sharply for parking, even at very low speeds.
Old Mar 30, 2012 | 11:40 AM
jonny.redneck
no cause it will do it on gravel too
Old Mar 30, 2012 | 11:44 AM
rbalsinger's Avatar
rbalsinger
Power steering pump? Does it only squeak when you are turning the wheel to the limit, then stop if you release the wheel a little?
Old Mar 30, 2012 | 11:52 AM
jonny.redneck
it will do it even if i turn a half turn to all the way over
Old Mar 30, 2012 | 12:14 PM
1986F150six
1. Check the v-belt tension on the belt powering the P/S pump.
2. Check the fluid level in the P/S pump reservoir.
Old Mar 30, 2012 | 12:29 PM
1983F1503004x4's Avatar
1983F1503004x4
2x4 or 4x4?
It might be time for you to start replacing all your bushings. These trucks aren't exactly new by now.
Wheel bearings too, maybe?
It could be anything up front that rotates or turns, honestly.
Old Mar 30, 2012 | 12:38 PM
rbalsinger's Avatar
rbalsinger
Originally Posted by 1983F1503004x4
2x4 or 4x4?
....or is broken. If it is definitely a squeak and not a squeal maybe a spring or shock mount is moving around. The bushing idea is likely as well. Get under there and look for shiny metal. There likely won't be much!
Old Mar 31, 2012 | 05:46 AM
82f100460's Avatar
82f100460
Do you feel a "clunk" when you come to a stop and then when you let off the brake it feels like it releases?
Look at your radius arm bushings...not sure if these would squeak or not when turning but they wear out.
Also your spring bushings (both called insulators in the master parts catalog in case your ordering parts).
As stated above....look around at all of them as see what seems to be wearing out.
You state "squeaking" which is why I'm looking at bushings. Is it really a "squeak" or a constant "squeal" when you turn the wheel. That would be more of the power steering / pump / belts as suggested above.
Old Mar 31, 2012 | 12:58 PM
81ChopTop's Avatar
81ChopTop
Got a sway bar on there?
EliteF250
May 4, 2014 12:44 PM
metriccar
Mar 16, 2012 08:14 AM
chandler1997
1997 - 2003 F150
Sep 6, 2008 10:58 PM
mxhowes1
Jun 24, 2008 12:18 PM
wresleu
1997 - 2003 F150
Dec 3, 2007 12:03 AM
